MKL_Complex16
Dan4
I am using MKL's "zgetri" function in C. Since I am porting our code to use MKL, it is not possible to change our data type from "complex" to MKL's "Complex16" everywhere in the code. The MKL's User Guide gives a solution to this to add these lines:
#define MKL_Complex16 std::complex
#include "mkl.h"
I would like to know will it work correctly if I use my old matrices which use complex, of course if I use a column major matrix for compatibility sake with Fortran?
I used this method and when I compile the code I get this error:
../include/mkl_types.h(43): error: expected a ";"
} MKL_Complex16;
../include/mkl_types.h(43): warning #64: declaration does not declare anything
} MKL_Complex16;
why this happens? This is the solution from MKL's user guide. Thanks for you help.
D.
Gennady_F_Intel
Quoting - danltu.se
#include "mkl.h"
} MKL_Complex16;
} MKL_Complex16;
D.
Dan,
- it should work correctly :).
- do you mean the example 7-2 Calling a Complex BLAS Level 1 Function from C++?
--Gennady
