7303 Discussions
MKL DCT using fortran: scaling prefactors and complex-type arrays
Thomas_G_7
I'm currently using the MKL to calculate some DCT on complex-type fortran arrays. My fortran module has a first initialization routine that looks like
   subroutine initialize(this,n, ni, nd)
     class(costf_odd_t) :: this
     !-- Input variables
     integer, intent(in) :: n
     integer, intent(in) :: ni
     integer, intent(in) :: nd
     !-- Local variables:
     integer :: stat
     real(cp) :: fac
     real(cp) :: work(n)
     this%nRad = n
     allocate(this%i_costf_init(128))
     allocate(this%d_costf_init(1:5*(n-1)/2+2))
     call d_init_trig_transform(n-1,MKL_COSINE_TRANSFORM,this%i_costf_init,this%d_costf_init,stat)
     call d_commit_trig_transform(work,this%r2c_handle,this%i_costf_init,this%d_costf_init,stat)
     !fac = sqrt(half*real(this%nRad-1,cp))
     !stat = DftiSetValue(this%r2c_handle, DFTI_FORWARD_SCALE, fac)
     !stat = DftiCommitDescriptor(this%r2c_handle)
  end subroutine initialize
The actual DCT is then computed later on as follows
   subroutine costf1_complex(this,f,n_f_max,n_f_start,n_f_stop)
     !-- Input variables:
     integer,  intent(in) :: n_f_start,n_f_stop ! columns to be transformed
     integer,  intent(in) :: n_f_max
     complex(cp), intent(inout) :: f(n_f_max,this%nRad)
     real(cp) :: work_real(this%nRad)
     real(cp) :: work_imag(this%nRad)
     integer :: stat, n_f
     do n_f=n_f_start,n_f_stop
        work_real(:) = real(f(n_f,:))
        work_imag(:) = aimag(f(n_f,:))
        call d_forward_trig_transform(work_real,this%r2c_handle,this%i_costf_init,this%d_costf_init,stat)
        call d_forward_trig_transform(work_imag,this%r2c_handle,this%i_costf_init,this%d_costf_init,stat)
        f(n_f,:)=sqrt(half*real(this%nRad-1,cp))*cmplx(work_real,work_imag,kind=cp)
     end do
  end subroutine costf1_complex
It basically does what I want but I have several performance limitations since: (i) there is a pre-factor multiplication which is computed for each DCT, (ii) there is a memory copy due to the unsupported complex-type input arrays in the MKL trig transforms.
I tried fixing the first issue using the 3 last commented lines in the initialize subroutine above, but it didn't work, any idea here? Concerning the second issue, is there a possible way to avoid the memory allocation of the work arrays in the costf1_complex subroutine (maybe using the C-type pointers)?
Thanks!
Ying_H_Intel
Hi Thomas,
I) you mean the factor is fac = sqrt(half*real(this%nRad-1,cp)) and
II)there are
14       work_imag(:) = aimag(f(n_f,:))
Right?
Because of the below reason,
1) trig function ask continous input array
2) it don't factor option, you can't pin the pre-factor to internal FFT Descriptor.
Your current code looks the right solution that MKL trig transforms can support so far.
or other consideration,
1) like create feature request ask complex DCT support
2) your algorithm,   for example,
if there is the possible to change the input data, so no copy needed?
the possible for use MKL FFT to caculate your DCT?
it seems do the row by row DCT. The pre-defined is fixed between each row, you may put
out of the do loop and call some function like cblas_zscal. to improve the speed.
Ying
