7234 Discussions
MKL ERROR: Parameter 2 was incorrect on entry to vdRngUniform
xiaomingg
I try to change a fortran 77 program using IMSL to a fortran 90 program using MKL. I got the error message:
MKL ERROR: Parameter 2 was incorrect on entry to vdRngUniform.
I don't know what does it mean. How to fix the problem. Thank you.
Sherry
My program looks like this:
INCLUDE 'mkl_vsl.fi'
PROGRAM MYPROG
USE LINK
USE MKL_VSL
USE MKL_VSL_TYPE
USE F95_PRECISION
USE BLAS95
USE LAPACK95
IMPLICIT INTEGER*4 (I-N), REAL(8) (A-H,O-Z)
INTEGER, PARAMETER:: ISEED=123
! RANDOM GENERATOR
TYPE (VSL_STREAM_STATE) :: STREAM
INTEGER :: BRNG, METHOD, STATUS = 0, INFO = 0
integer(kind=4) ERRCODE
! INITIALIZE FOR RANDOM SAMPLING
BRNG = VSL_BRNG_MCG59
ERRCODE=VSLNEWSTREAM( STREAM, BRNG, ISEED )
IF (ERRCODE /= VSL_ERROR_OK) THEN
PRINT *, 'CREATING RANDOM STREAM ERROR: ', ERRCODE
ENDIF
DO 30 I1=1,M
CALL CALC(I,....)
30 continue
STOP
END PROGRAM MYPROG
SUBROUTINE CALC(I,....)
! RANDOM GENERATOR
! TYPE (VSL_STREAM_STATE) :: STREAM
! INTEGER :: BRNG, METHOD, STATUS = 0, INFO = 0
! integer(kind=4) ERRCODE
METHOD = VSL_METHOD_DUNIFORM_STD
STATUS = VDRNGUNIFORM( METHOD, STREAM, 100, R, 0, 1.0 )
IF (STATUS /= VSL_ERROR_OK) THEN
PRINT *, 'GENERATING ERROR FOR X: ', STATUS
ENDIF
RETURN
END
Andrey_N_Intel
Hello Sherry,
I developed a short test case that demonstrates use of Intel MKL generators in the application that does random number generation inthe subroutine. I tried to reproduce your code as much as possible. The test case, whichis built using Intel Fortran compiler, runs and printsrandom numbers obtained as result of call to Intel MKL Uniform RNG. Please, let me know if this helps to resolve the compilation and runissues on your side.
Andrey
PROGRAM MYPROG
USE MKL_VSL
USE MKL_VSL_TYPE
INTERFACE
SUBROUTINE CALC(I, STREAM)
USE MKL_VSL
USE MKL_VSL_TYPE
INTEGER I
END SUBROUTINE
END INTERFACE
ENDIF
CALL CALC(1, STREAM)
ERRCODE=VSLDELETESTREAM( STREAM )
PRINT *, 'DELETING RANDOM STREAM ERROR: ', ERRCODE
ENDIF
STOP
END PROGRAM MYPROG
USE MKL_VSL
USE MKL_VSL_TYPE
INTEGER I
REAL(KIND=8) R(100)
INTEGER METHOD
INTEGER(KIND=4) STATUS
INTEGER J
METHOD = VSL_RNG_METHOD_UNIFORM_STD
STATUS = VDRNGUNIFORM( METHOD, STREAM, 100, R, 0.0D0, 1.0D0 )
ENDIF
DO J=1,100
PRINT *, R(J)
END DO
RETURN
END
mecej4
Why did you make the TYPE and other declarations inoperative in your subroutine by making them comment lines, causing STREAM to become REAL, etc., because of the implicit typing?
xiaomingg
Quoting mecej4
If I don't comment them out, I get error message when I compile.
error #6633: The type of the actual argument differs from the type of the dummy argument. [STREAM]
patterncnty1_2.f90(272): error #6633: The type of the actual argument differs from the type of the dummy argument. [BRNG]
patterncnty1_2.f90(1077): error #6457: This derived type name has not been declared. [VSL_STREAM_STATE]
Gennady_F_Intel
why don't you use the existing examples? see - \examples\vslf\sources\vdrnguniform.f.
mecej4
Killing the messenger does not prevent bad things from happening. By relying incorrectly on implicit typing, you promoted the compile time errors to run time aborts.
xiaomingg
Yes, I try to follow the example. The example has everything in one program. My program has a few subroutines. I have to sample uniform, binomial, normal in my subroutine.
xiaomingg
Yes, you are absolutely right.
I use IMPLICIT NONE now, but I still get the following compile time errors. I don't know what the error messages mean.
Can anyone please help? Thank you very much.
error #6404: This name does not have a type, and must have an explicit type. [VSL_METHOD_DUNIFORM_STD]
error #6404: This name does not have a type, and must have an explicit type. [VDRNGUNIFORM]
STATUS = VDRNGUNIFORM( METHOD, STREAM, II, OMEGA, a, b )
error #6404: This name does not have a type, and must have an explicit type. [VSL_ERROR_OK]
compilation aborted for patterncnty1_2.f90 (code 1)
TimP
If you have have both the f77 vsl include file and the f90 USE, as you showed at the top, that may account for the error.
Andrey_N_Intel
Hello Sherry,
Andrey
PROGRAM MYPROG
USE MKL_VSL
USE MKL_VSL_TYPE
INTERFACE
USE MKL_VSL
USE MKL_VSL_TYPE
INTEGER I
END SUBROUTINE
END INTERFACE
ENDIF
ENDIF
STOP
END PROGRAM MYPROG
USE MKL_VSL
USE MKL_VSL_TYPE
INTEGER I
REAL(KIND=8) R(100)
INTEGER METHOD
INTEGER J
ENDIF
DO J=1,100
PRINT *, R(J)
END DO
RETURN
END
xiaomingg
Hi Andrey,
Thank you for your example. It works fine. I guess I need the interface block in my code. If I have main program calls subroutine A, and subroutine A calls subroutine B. I need interface block in subroutine A before calling subroutine B, am I right?
Sherry
mecej4
An interface block is one method for providing a required explicit interface to a routine.
Another method is to declare the called or referenced routines in a module and, in the caller(s), USE that module.
The Fortran reference manual should be consulted regarding circumstances in which an explicit interface is obligatory.
Andrey_N_Intel
Hi Sherry,
As Mecej4 mentioned in his post,please chooseone of the approaches for the explicit interface specification that would workin your app:either interface statement (as in the example above), ora module based scheme (please, have a look atmkl_vsl.f90 fileas one possible example).
Andrey
