MKL FFT and Inverse FFT
Dakin
Dear. Intel Members
I gottwo answers from intel engineer about MKL FFT and Inverse FFT
but I got a problem.
from first answer. Ican get a right forward FFT signal about our data. but I can get a inverse data
(Our data consist of 14bit WORD type so I usemy data transfer to float)
from second answer.I canget a correct Inverse data But I can't use FFT Data because some different
things compair malab result.
below is your two answer.
and I attached1 file about your answer result
this issue is very urgent
If you able Please answer ASAP
Thanks~
All the Best
1.
int i,j;
const int ROWS=3072, COLS=2560;
const int ROWSIZE=COLS, COLSIZE=ROWS;
_complex *xx = new _complex[ROWS*COLS];
memset(xx,1,2*sizeof(float)*ROWS*COLS); /* zero fill initialization */
int r,c;
for(r=0;r
for (c=0;c
xx[*ROWSIZE+(c)].x = (img[*ROWSIZE+(c)]);
xx[*ROWSIZE+(c)].y = (img[*ROWSIZE+(c)]);
int Height_f = ROWS;
int Widtht_f = COLS;
DFTI_DESCRIPTOR_HANDLE rowfft;
DFTI_DESCRIPTOR_HANDLE colfft;
MKL_LONG status;
MKL_LONG l[2];
float src;
DftiCreateDescriptor(&rowfft, DFTI_SINGLE, DFTI_COMPLEX, 1, ROWSIZE); /* stride 1 by default */
DftiSetValue(rowfft, DFTI_NUMBER_OF_TRANSFORMS, (MKL_LONG)ROWS);
DftiSetValue(rowfft, DFTI_INPUT_DISTANCE, (MKL_LONG)ROWSIZE);
DftiSetValue(rowfft, DFTI_OUTPUT_DISTANCE, (MKL_LONG)ROWSIZE);
DftiCreateDescriptor(&colfft, DFTI_SINGLE, DFTI_COMPLEX, 1, COLSIZE); /* will set strides */
MKL_LONG colfft_strides[] = {0, ROWSIZE};
DftiSetValue(colfft, DFTI_INPUT_STRIDES, colfft_strides);
DftiSetValue(colfft, DFTI_OUTPUT_STRIDES, colfft_strides);
DftiSetValue(colfft, DFTI_NUMBER_OF_TRANSFORMS, (MKL_LONG)COLS);
DftiSetValue(colfft, DFTI_INPUT_DISTANCE, (MKL_LONG)1);
DftiSetValue(colfft, DFTI_OUTPUT_DISTANCE, (MKL_LONG)1);
status = DftiCommitDescriptor( rowfft);
DftiComputeForward(rowfft, xx);
status = DftiCommitDescriptor( colfft);
DftiComputeForward(colfft, xx);
2. Second Answer
#define x(r,c) x[*ROWSIZE+(c)] /* explicit row-major indexing */
typedef struct {float x,y;} singlecomplex;
singlecomplex* xx;
xx = (singlecomplex *)malloc(2*sizeof(float)*ROWS*COLS); /* zero fill initialization -> Ones pading */
memset(xx,0,2*sizeof(float)*ROWS*COLS); /* zero fill initialization */
int r,c;
for(r=0;r
for (c=0;c
MKL_LONG status;
float src;
status = DftiCreateDescriptor(&rowfft, DFTI_SINGLE, DFTI_COMPLEX, 1, (MKL_LONG)ROWSIZE); /* stride 1 by default */
status = DftiSetValue(rowfft, DFTI_NUMBER_OF_TRANSFORMS, (MKL_LONG)ROWS);
status = DftiSetValue(rowfft, DFTI_INPUT_DISTANCE, (MKL_LONG)ROWSIZE);
status = DftiSetValue(rowfft, DFTI_BACKWARD_SCALE, 1.0/(ROWS*COLS));
// status = DftiSetValue(rowfft, DFTI_OUTPUT_DISTANCE, (MKL_LONG)ROWSIZE); // not needed for in-place
status = DftiCreateDescriptor(&colfft, DFTI_SINGLE, DFTI_COMPLEX, 1, (MKL_LONG)COLSIZE); /* will set strides */
status = DftiSetValue(colfft, DFTI_NUMBER_OF_TRANSFORMS, (MKL_LONG)COLS);
status = DftiSetValue(colfft, DFTI_INPUT_DISTANCE, (MKL_LONG)1);
// status = DftiSetValue(colfft, DFTI_OUTPUT_DISTANCE, (MKL_LONG)1); // not needed for in-place
status = DftiSetValue(colfft, DFTI_INPUT_STRIDES, colfft_strides);
// status = DftiSetValue(colfft, DFTI_OUTPUT_STRIDES, colfft_strides); // not needed for in-place
status = DftiComputeForward(rowfft, xx);
status = DftiComputeForward(colfft, xx);
// ///Inverse FFT
status = DftiComputeBackward(colfft, xx);
status = DftiComputeBackward(rowfft, xx);
barragan_villanueva_
Valued Contributor I
The difference between these two variants is in using normalization of trnasforms:
But also please correct your second variant which is not currently correspond to what wassuggested to you.
I means, not needed DftiCommitDescriptor callsafter line // ///Inverse FFT.
Maybe something else was not corrected by you.
Dakin
Hi
Thanks to your fast answer
your answer:
I means, not needed DftiCommitDescriptor calls after line // ///Inverse FFT.
-> It is just test code. When I use inverse FFT I don't call DftiCommitDescriptor
Already I attachedmy result file.
I testmy code usingyour code(first code), and your engineer code (2).
Result of FFTusing first code I can see frequency. so I can calculate something.
but I can't get a incerse FFT image.
general, As I know FFT + inverse FFT -> Original image (if I don't treat anything)
by your 1 code I test fft and Inverse fft but I can't get a original image.
When I using code 2
in this case I can get FFT + incerse FFT = original image
but in the FFT image, I can't see the signal. and I cant calculate frequency.
my needs : FFT -> find frequency position information and some calculate and inverse fft
all the best
Dakin
Dakin,
Looks like it was you who startedthread about The FFT adjusts only half size...
And that root cause was in interpretation/visualization of data after FFTs. So, please double check your testcase again.
Anyway, it will benice to see your self-contained testcase to reproduce your new problem in order to help you.
Dakin
Victor
you are right my issee Start from FFT harf size .
I also test from harfsize test. I also same result only harf size result and can't get inverse FFT image
by sample code in the Intel MKL manual.
fortunately I can get a kind and nice answer from you soI can get a full size FFT result (I can see frequency information) butcan't get a inverse FFT
Another member give a one clue normalization so I can get a FFT and IFFT but I can't get frequency information data
I also check my project and code again and again.
If you have a clue.
Please advice for me.
I'm very thanks to your kindness and help
all the best
Dakin
Dakin,
Please add checking of DFTI status after all DFTI calls to be sure that all is OK.
E.g. see MKLROOT/examples/dftc
if (! DftiErrorClass(Status, DFTI_NO_ERROR)) {
printf(" TEST FAILED : after ....)\n");
failure++;
goto FREE_DESCRIPTOR;
