7302 Discussions
MKL.NET.Matrix Nuget package in docker container
womackra
Encountering errors with matrix multiplication using MKL.NET.Matrix Nuget package in a docker container
Dockerfile =======================
FROM mcr.microsoft.com/dotnet/sdk:6.0-windowsservercore-ltsc2022
WORKDIR c:/test/
COPY test.csproj test.csproj
COPY test.cs test.cs
RUN dotnet build
RUN dotnet test
test.csproj file: =======================
<Project Sdk="Microsoft.NET.Sdk">
  <PropertyGroup>
    <TargetFrameworks>net6.0</TargetFrameworks>
  </PropertyGroup>
  <ItemGroup>
    <PackageReference Include="MKL.NET.Matrix" Version="1.1.1"/>
    <PackageReference Include="MKL.NET.win-x64" Version="2022.0.0.115" />
    <PackageReference Include="MSTest" Version="3.6.2"/>
  </ItemGroup>
</Project>
test.cs file: =======================
using System;
using System.Reflection;
using System.Runtime.InteropServices;
using Microsoft.VisualStudio.TestTools.UnitTesting;
[TestClass]
public class matrix_test {
    [TestMethod]
    public void matrix_multiply_test(){
        MKLNET.matrix matrixA = new MKLNET.matrix(6, 6);
        for (int i = 0; i < matrixA.Cols; ++i) {
            for (int j = 0; j < matrixA.Rows; ++j) {
                    matrixA[i, j] = (i + 1) * (j + 1);
        try { MKLNET.matrix result = matrixA * matrixA;
        } catch (ExternalException e) {
            Console.WriteLine(e.ErrorCode);
            Console.WriteLine(e.Source);
            Assert.Fail();
        Assert.IsTrue(true);
output (when catching the exception): =======================
A total of 1 test files matched the specified pattern.
Failed matrix_multiply_test [106 ms]
Error Message:
Assert.Fail failed.
Stack Trace:
at matrix_test.matrix_multiply_test() in C:\test\test.cs:line 20
Standard Output Messages:
-2147467259 (translates to 0x80004005, an Unspecified Error)
MKL.NET
output (not catching the exception) =======================
System.Runtime.InteropServices.SEHException: External component has thrown an exception.
Stack Trace:
at MKLNET.Blas.Unsafe.gemm(Layout Layout, Trans TransA, Trans TransB, Int32 M, Int32 N, Int32 K, Double alpha, Double* A, Int32 lda, Double* B, Int32 ldb, Double beta, Double* C, Int32 ldc)
at MKLNET.Expression.MatrixMultiply.Evaluate()
at MKLNET.Expression.MatrixExpression.op_Implicit(MatrixExpression a)
at matrix_test.matrix_multiply_test() in C:\test\test.cs:line 16
Some scenarios where this error doesn't exist (that could help isolate the issue):
1. when using mcr.microsoft.com/dotnet/sdk:6.0-jammy image, indicating that the external failure is due to something specific to the windows image. To run in a linux container, I change the runtime package to MKL.NET.linux-x64 and change dockerfile test path to /test/
2. executing the unit test outside of a docker image, indicating some expected component from windows is missing in the docker image
Insight on why this error could be happening or how to get more information out of the external failure would be greatly helpful. Thanks
Aleksandra_K
After reproducing your case, I think that the is an issue related to dynamic libraries in the Docker environment. You can try to use tools like Understanding the Dependencies of a Visual C++ Application | Microsoft Learn to check this.
Aleksandra
Aleksandra_K
Did you get a chance to try the instructions I sent earlier?
Aleksandra
Aleksandra_K
Due to the lack of response, I am closing the ticket. You can post in this forum If you have further queries.
Aleksandra
