MKL PARDISO Manual Question
xian-zhong_guous_cd-
I am comfused by following instruction at MKL reference manual 630813-027US p2179:
"Note that if iparm(60) is equal to 1 or 2, and the total peak
memory needed for strong local arrays is less than
MKL_PARDISO_OOC_MAX_CORE_SIZE, the program stops
with error -9. In this case, increase of
MKL_PARDISO_OOC_MAX_CORE_SIZE is recommended."
Sergey_P_Intel2
Let me clarify this instruction: PARDISO has two modes of execution: In-Core, when all LU factor are fit in RAM, and Out-of-core (OOC) otherwise. In the last case most of LU factors are stored on hard disk. OOC mode (iparm(60) = 1 or 2) requires information about memory which PARDISO can utilize - it determines by MKL_PARDISO_OOC_MAX_CORE_SIZE parameter; and PARDISO stops with error= -9 in the case when the specified amount memory is not enough for solving the task. In this case the amount of memory should be increased to solve it.
Sergey
You indicate if
total peak memory > MKL_PARDISO_OOC_MAX_CORE_SIZE, PARDISO stops with error=-9. That makes perfect sense.
However, the manual seems indicate
total peak memory < MKL_PARDISO_OOC_MAX_CORE_SIZE, PARDISO stops with error=-9.
That's where my confusion is.
Two more questions:
1. in-core vs OOC: it seems the most flexbile setting is iparm(60)=1 (letting PARDISO to decide). My question is: is iparm(60)=1 as efficient as explicit setting? For example, in article Tips using PARDISO(http://software.intel.com/en-us/articles/pardiso-tips/) , I found following:
"Performance recommendations
To achieve the best performance, we do not recommend the use of the out-of-core (OOC) PARDISO for small matrices. We recommend using the in-core PARDISO for all cases where the memory required for storing PARDISO factors exceeds the RAM by less than 30%. The size of the factors in kbytes can be obtained with the help of iparm(17) after phase 11 (see Intel MKL reference manual)."
This seems indicate I should use the ohase 11 result to decide in-core or OOC and set iparm(60)=0 or iparm(60)=2 myself.
2. OOC not threading: I found following in article How to use OOC PARDISO (http://software.intel.com/en-us/articles/how-to-use-ooc-pardiso)
"The current OOC version does not use threading, thus both the parameter iparm(3) and the variable MKL_NUM_THREADS must be set to 1 when iparm(60) is equal to 1 or 2."
Does this mean OOC is running in sequential mode (instead of parallel shared memory mode)?
Gennady_F_Intel
Thank you for pointing out the mistake. We will correct that in the future updates.
--Gennady
Can someone answer above two questions about OOC for me? Thanks.
Alexander_K_Intel2
Answer on first question: both variants are possible. The sentence from manual that you mention means that sometimes in-core version of PARDISO could use HDD in swop and provide better performance than OOC PARDISO. As about second question: it does depend from version of MKL you used. If you use 10.2 update 2 of latter version then OOC PARDISO version is parallelized
With best regards,
Alexander Kalinkin
Gennady_F_Intel
xian-zhong, see the documentation of the latest versions ( 10.2 update7 and 10.3.1). This problem has been fixed there. As an example see the snip from this doc ( 10.3. Update1 - bundled with Composer XE 2011):
Ifiparm(60)is equal to 1 or 2, and the total peak memory needed for strong local arrays is more thanMKL_PARDISO_OOC_MAX_CORE_SIZE, the program stops with error -9. In this case, increaseMKL_PARDISO_OOC_MAX_CORE_SIZE.
Typo: strong should be storing, I believe.
Gennady_F_Intel
I agree with this observation. Will be fixed into the next update.
