7298 Discussions
MKL Performance issue in threaded application
Xiaohui_Z_Intel
Hi
We are working on RNN kernel optimization and we are trying to parallel 2 SGEMM on 2 socket SKX6148 server( 20 core per socket).
The SGEMM size is M = 20, N = 2400, K = 800.
Our target is to map the first SGEMM to socket0 and the other SGEMM to socket1.
We measured the GFLOPS with this benchmark(https://github.com/xhzhao/GemmEfficiency/tree/tbb), and got the following performance data:
I found that the performance of OMP+MKL or TBB MKL is not as good as we expect, and i'm not sure if i miss something with MKL in threaded application.
BTW, the pthread+MKL solution is not suitable for our real case , as it will double the threads and make the performance even worse.
Thanks in advance.
