MKL_RT.DLL is missing from your computer
philippe_d_
I configured my software with cmake on windows 7 with the MKL library.
The code compiles and links OK, but when trying to execute I get the above message. I do link with MKL_RT.LIB in cmake and there
is no file MKL_RT.DLL on my computer.
Was this file missing during installing MKL?
mecej4
The MKL DLLs are in <installation root directory>\compilers_and_libraries_<version_no>\windows\redist\<arch>\mkl. For example, one installation has the following directory with these DLLs:
     c:\LANG\PS2018\compilers_and_libraries_2018.1.156\windows\redist\ia32\mkl
Make sure that this directory is in your execution path.
mecej4
philippe_d_
Thank you for your reply.
In the directory you name there exists a file named : mkl_rt.lib
But there is no file mkl_rt.dll, which is the file my program wants to access upon launch.
The directory where the libraries of MKL are located is in the execution path.
mecej4
The LIB files are not distributable, and should not exist in a ...\redist\... subdirectory. Something is wrong with your installation.
philippe_d_
Thanks again. I managed to run the program by putting the ...\redist\ directory in my execution path.
In a sense the Intel manual is not precise. The ..\redist\ directory should be in the execution path. I believe to have read that the ..\lib\... directory should be in the execution path. Probably both directories need to be in the execution path?
mecej4
Static libraries (extension .LIB) are not executable. so their directory should not be in PATH. Intel compiler packages put dynamic and static libraries into different subdirectories. The LIB environment variable is used by the linker to find static libraries. Dynamic libraries, on the other hand, are found using PATH.
In contrast to that, if you have IMSL, you will find both static and dynamic IMSL libraries in its LIB directory.
