7303 Discussions
MKL_SPARSE_?_QR invalid input error (Fortran)
Bakee
I am experimenting the Sparse QR library to solve a linear system of equations. When I run the attached file, I get the following output:
0
0
0
3
The last output "3" indicates "SPARSE_STATUS_INVALID_VALUE The input parameters contain an invalid value."
Can anyone help?
Gennady_F_Intel
you put the input parameters into wriong order, fixing that, you will see the correct answer:
!stat = MKL_SPARSE_S_QR (SPARSE_OPERATION_NON_TRANSPOSE, csrA, descrA, SPARSE_LAYOUT_ROW_MAJOR, x, cols, ldx, b, ldb)
stat = MKL_SPARSE_S_QR (SPARSE_OPERATION_NON_TRANSPOSE, csrA, descrA, SPARSE_LAYOUT_ROW_MAJOR, cols, x,  ldx, b, ldb)
_mkl_forum\u815245>test.exe
           0
           0
           0
           0
Gennady_F_Intel
           0
           0
           0
           0
Bakee
Thank you so much for the prompt reply. It solved the problem.
Here is a feedback: the page 324 of the documentation "Intel Math Kernel Library Developer Reference" is incorrect:
Gennady_F_Intel
The problem has been fixed in MKL version 2019 update 5. Please let us know if the problem still exists on your side.
Gennady_F_Intel
MKL v.2020 has been released and contains the fix of this problem either.
