MKL and the Parallel option
cppcoder
I'm using Visual Studio 2008, Intel compiler v11.1 and the MKL library that comes with it. I started my project using the Sequential option for MKL but now I want to use the parallel option. However, when I switch to parallel and recompile (release version), I neither see any performance improvement, nor see that the executable uses more than the CPUs that the sequential version uses (one). I have 8 cores(EDITED) more than 5 Gb RAM, using Windows 7 x64, and generating an x64 executable (fp model used is precise)
In my case, I'm generating about ~800k random numbers with VSL functions, and then getting the log of those numbers using another VSL function. I think that such volume of computations should benefit from parallelism. What am I doing wrong?
The only thing I change is the MKL option from Sequential to Parallel.
EDIT: Setting the variableMKL_NUM_THREADS=4 before executing my program from the command line, does not yield any change from what I stated above.
Gennady_F_Intel
That's an unexpected behaviour. We need to check it on our side. Did you check the execution time in the case of sequentialvs threaded version?
cppcoder
Yes, it's approximately the same time (which I don't find surprising given than no more CPUs appear to be used)
I'm sorry, but it's not the case. I was taking the time in other parts of my program together with the VSL functions. Now that I isolated the times that VSL routines take, I have notice the following (all times were measured with pairs ofGetTickCount() calls):
  1. Execution of the sequential version takes much less time (15-32 ms in several runs) than the parallel version (~1000 - ~2000 ms in several runs)
  2. CPU usage never goes beyond 20% even when I change the number of threads with MKL_NUM_THREADSto the maximum number of processors (8)
I guess MKL is using several cores after all, but the computations I do (random number generation and taking log of those) are not demanding enough to notice any noticeable difference by humans, or to benefit from parallelism
If you have a different take, please let me know.
Ilya_B_Intel
cppcoder, can you please name exact routines you were using for RNG generation with method used, and which log function are you using?
it would be also beneficial if you can provide your linking line.
Seth_Sampson
I use MKL and IPP to compute FFT on one computer( E8200, 2cores, 2G mem,win XP) and the other ( Xeon X5670 *2, 24 cores with HT, 64G mem, Win7 x64), but the results are of no significant changes. The CPU usage of the Xeon X5670 never goes beyond 10%, and I am also confused.
TimP
If your objective is to keep the hyperthreads busy on the Windows task manager, without caring about performance, did you read the discussions about MKL_DYNAMIC? You may be spending much of your time in MKL functions which can't use so many threads, so you would have to answer the questions about specifics before you could get expert comments.
cppcoder
Yes, I use these functions in the order specified below:
vdRngGamma
vdLog10
vdRngUniform
vdLog10
cppcoder
(duplicated)
Ilya_B_Intel
cppcoder,
vdRngGamma and vdUniform functions are not threaded in MKL. Threaded functins vdLog10 takes around 10-15% of overall time in this call sequence and thus benefit from their parallelization is not visible.
In general case threading of sequences of VML and VSL function calls is more efficient on higher level than function-by-function. Higher level helps to minimize threading overheads and cache issues.
In order to utilize threading of VSL functions you might use one of techniqes:
  • Creating independent streams
  • Splitting streams into blocks withvslSkipAheadStream function
  • Splitting streams into severaldisjoint subsequences withvslLeapfrogStream function
