MKL bug mailing list
jaewonj
Is there any mailing list where I can send a bug report?
TimP
Quoting - jaewonj
If you haven't created a support account on https://premier.intel.com, you can do so by registering your serial number at https://registrationcenter.intel.com. Then you can submit the bug report on premier.
Gennady_F_Intel
Quoting - jaewonj
Gennady,
I think this is a threading bug. In case I missed something, please let me know. Thanks.
When performing dense sparse level 3 operation (mkl_dcsrmm), I got inconsistent result depending on the number of cores used. Please see the attached c file (dcsrmm.c).
B (1001-by-1001) dense matrix with only 1 nonzero, B(0,0) = 1.0.
A (1001-by-1001) CSR sparse matrix also with only 1 nz, A(0,0) = 1.0
For C = B * A, I should get C(0,0) = 1.0 and this happens when I use 1 core or more than 2 cores. However, if I set OMP_NUM_THREADS=2, I get C(0,0) = 0.0 which is incorrect.
It seems this can be reproducible on all platforms with more than 2 cores.
I'm using MKL 10.2.2.
Jaewon
Jaewon,
Thanks for the test.
It's easy to check the is it threading bug or not to link the test with
sequential libraries.
Can you check it on your side?
--Gennady
jaewonj
Jaewon,
--Gennady
Gennady,
Unable to reproduce with sequential libraries.
Jaewon
Gennady_F_Intel
Quoting - jaewonj
Gennady,
Jaewon
Jaewon,
yes i've got the same result. We will investigate the problem and will back if any news asap.
--Gennady
jaewonj
Jaewon,
--Gennady
Gennady,
Any update on this issue?
Jaewon
ali_m_2
I have tried the following simple program to generate random numbers for parallel threads using Cilk.
#include "mkl.h"
#include <cilk/cilk.h>
#define NUM_THREADS 2
VSLStreamStatePtr stream[NUM_THREADS];
void cal(int sid) {
    double buff[1024];
    vdRngUniform(VSL_METHOD_DUNIFORM_STD, stream[sid], 1024, buff, -1.0, 1.0);
int main() {
    for (int i = 0; i < NUM_THREADS; i++) {
        vslNewStream(&stream, VSL_BRNG_WH, 1);
        cilk_spawn cal(i);
    cilk_sync;
        vslDeleteStream(&stream);
    return 0;
The I compile it with icpc compiler icpc (ICC) 14.0.1 20131008.
icpc -std=c++11 -fopenmp -mkl -I/opt/intel/include/ -g -o pi_mont pi_mont.cpp
If I run it inside cilkscreen, it shows the race condition error.
$ cilkscreen ./pi_mont
Cilkscreen Race Detector V2.0.0, Build 4225
Race condition on location 0x7fc000ee8d00
  write access at 0x7fc000b877e3: (vdRngUniform+0xf3)
  read access at 0x7fc000b87761: (vdRngUniform+0x71)
    called by 0x40172c: (/localstore/theorie/amirsol/paralleluct/pi_mont.cpp:10, cal+0x60)
    called by 0x401a3a: (/localstore/theorie/amirsol/paralleluct/pi_mont.cpp:20, main+0x2fc)
1 error found by Cilkscreen
Cilkscreen suppressed 1 duplicate error messages
Ali
ali_m_2
#include "mkl.h"
void cal(int sid) {
    double buff[1024];
int main() {
        cilk_spawn cal(i);
    cilk_sync;
    return 0;
Ali
Andrey_N_Intel
