7302 Discussions
MKL cblas_dgemm huge performance gap on intelOneAPI and Parallel Studio Studio
Rizwan1
Previously I had tested mkl cblas_dgemm for m=n=k=10000 and found a performance of approximately 2 TFlop but now the same give me a performance of around 0.8 TFlops.
Case 1:
CentOS 7.2.* and Intel Parallel Studio XE
MKL cblas_dgemm
m=n=k=10000
Performance: 1900+ GFlops
Case 2:
CentOS 8.5.* and Intel OneAPI
MKL cblas_dgemm
m=n=k=1000
Performance: 750+ GFlops
Why this is the huge gap. something is wrong
What is the reason?
Please assist and guide
VidyalathaB_Intel
Could you please let us know with what versions of Intel parallel studio xe and oneAPI you have observed the differences in performance and also how did you calculate the performance (gflops) so that it would help us to investigate your issue from our end?
Vidya.
Rizwan1
In 2017, Intel Parallel Studio XE Update 1 was used, and the performance of cblas_dgemm was about 2+ TFlops.
In the next step, I used the MKL and OpenMP libraries that came with the previous installation, and the Intel C compiler that came with HPC kit version 2021. I still got a performance of about 1.95 TTFlops. This setup was on CentOS 7.2
Now I have installed CentOS 8.5 on Intel Xeon Phi 7250, the performance of cblas_dgemm is around 0.75 TFlops, which is worse than before. I have installed oneAPI through GUI Installer
VidyalathaB_Intel
Could you please provide us with the timings that you are getting for both cases?
Time taken when working with >> In 2017, Intel Parallel Studio XE Update 1.
Time taken when working with >> installed oneAPI through GUI Installer
Vidya.
Rizwan1
I can't provide the exact timing information because an other researcher work at that time. But the rough estimate is about its near October 2017.
I have installed oneAPI just couple of days ago less that one week from the current date
VidyalathaB_Intel
Let me rephrase my question.
The execution time of your code with the latest oneMKL 2022 and also with MKL 2017 (if possible)?
Vidya.
Rizwan1
For MKL2017
OS: CentOS 7.2
M=N=K=10000
Execution Time 1.02 Seconds on  Intel Xeon Phi 7250 with 68 Cores
For OneMKL2022
OS: CentOS 8.5
M=N=K=10000
Execution Time 3.17 Seconds on  Intel Xeon Phi 7250 with 68 Cores
Muhammad Rizwan
mecej4
These performance comparisons are likely to be quite variable depending on system load, number of active users, etc.
On a Windows PC with an i7-10710U (low power) NUC, here are my timing results for DGEMM with m=n=k=2000, alpha = 1, beta = 2:
2014 0.445 s
2016 U8 0.242
2019.1 U3 0.151
2021.5 0.152
For each case, I compiled with /Qopenmp /Qxhost and ran the program three or four times. The reported times above are the best of these three or four runs.
For comparison purposes, it would be useful if you were to run the following program on your system and provide the results.
program xdgemm
implicit none
integer, parameter :: N = 2000
double precision, allocatable, dimension(:,:) :: A, B, C
integer :: m,k
double precision :: alpha = 1d0, beta = 2d0
real t1,t2
allocate (A(N,N),B(N,N),C(N,N))
m = N
k = N
call random_number(A)
call random_number(B)
call random_number(C)
call cpu_time(t1)
call dgemm('N','N',m,n,k,alpha,A,N,B,N,beta,C,N)
call cpu_time(t2)
print *,t2-t1,' secs'
end
Rizwan1
Dear
Are you kidding me?
I am informing issue for Linux system CentOS and highlighting totally different platform and you are sharing the script for the windows system.
Please understand the context and problem first.
VidyalathaB_Intel
Thanks for providing the details.
We are looking into this issue internally, we will get back to you soon.
Vidya.
Gennady_F_Intel
checking the problem on RH7 ( no CentOS available right now ) with MKL 2020.0.1 (the current) and MKL 2017.0 Update 2 on Intel(R) Xeon(R) Gold 6148 CPU @ 2.40GHz ( SkyLake CPU), I see ~ the same performance on my end:
MKL 2017 u2:
[gfedorov@skx2 05339303]$ MKL_VERBOSE=0 ./a.out 10000
 size == 10000, GFlops == 2343.43
 size == 10000, GFlops == 2251.49
lscpu, as well both MKL_VERBOSE=1 logs are attached for your reference.
I noticed you said about Xeon Phi CPU. Then It should be noted, that since MKL 2022, this CPU type has been deprecated. Please check the latest Release Notes following this link: https://cqpreview.intel.com/content/www/us/en/developer/articles/release-notes/onemkl-release-notes.html
Rizwan1
PLease share the valid url
Thanks for the update.
Please share, what version of oneAPI BaseKIT and HPCKit best fit for  Intel Xeon Phi 7250 and CentOS 8.5. How can I get the previous versions
Rizwan1
Could you please give a little favour and share the a.out binary file so that I can test it at my system
This will be a great help
Gennady_F_Intel
see the _stat2020.log attached. This is a statically linked executable.
I zipped _stat2020.out as *.log due to the *.out attachments are not acceptable by the forum engine.
the password - intelmklforum
Rizwan1
Rizwan1
Thanks but is this compressed in the windows environment or Linux environment
Rizwan1
Dear
Thanks for sharing the executable file. I executed it but I still get 762.311 GFlops on Intel Xeon Phi and CentOS 8.5.
Could you please also give me one favour? Could you please tell me the environment variable set up at your end?
I don't know why files that give 2+ TFlops previously now give less than 800 GFlops
I have installed intel one API 2022.0.1
Gennady_F_Intel
Could you run this 2022 executable with verbose mode enabled and share the output?
how to run:  MKL_VERBOSE=1  ./a.out 10000
Rizwan1
Gennady_F_Intel
Ok and then link your example against MKL 2017 and run with the same MKL_VERBOSE=1 on the same machine and share the log file, please.
Rizwan1
