MKL distribution problem
wilcox__nigel
I have a mixed language program that uses a fortran DLL that uses the MKL, everything works fine on the development machine but when I try to distribute it to another machine I get a module not found error when the program calls the DLL.  Through a process of elimination I have tracked the problem down to the MKL.  If I do not include the MKL in the link and remove all calls to MKL routines everything is fine.  As soon as I add the MKL to the link, I get the module not found error even with no calls to the MKL routines.  I have tried installing MKL onto the distribution machine, and adding all the redist MKL dlls to the installation folder but neither makes any difference.
I am using MKL 2019 update 4 on both machines.
Any ideas gratefully accepted.
wilcox__nigel
I may have found the problem to this.  If I set the MKL option to sequential rather than parallel then everything works fine.  The test distribution machine is only windows 10 home and maybe cannot handle parallel processing.
I would still be grateful for any clarification on this
wilcox__nigel
A further update, it appears to be a windows 10 problem as the parallel version will not run on win 10 pro, or win 10 home.
The development machine is Win 7 and so it looks to be some issue with compiling on win 7 and distributing to win 10.   I have not had a problem doing his with any other program so it appears peculiar to MKL.
Nigel
