7298 Discussions
MKL error C3861: 'vdSin': identifier not found
postaquestion
I'm writing a simple program using Visual Sudio 2005 C++ and the MKL but I'm simply unable to compile it. My program is using the sine function but the compiler gives me the error:
Error 1 error C3861: 'vdSin': identifier not found
Here's my code:
int n; //Number of element
double* angle;
double* result;
printf("***** Test Intel Sine Function ***** ");
*angle = 23;
vdSin(n,angle,result);
printf("Sine result of sin(%d) : %d ",*angle,*result);
I think I'm not including the proper lib file. How do I know which function goes with which library file?
Thank you.
dc-david
Theorder of includes had an influence:
The#include "mkl_vml.h" must be after the#include "stdafx.h"
Then, add the proper library as dependencies.
