MKL from Delphi 2007
esys-intel
Where can i find files interface for MKL 10.1 ?
thanks
Lionel
ArturGuzik
Valued Contributor I
Quoting - esys-intel
thanks
Lionel
The interfaces you can find in
mklinclude
(for both C and Fortran). All of the routines input/output types should be described in the docs, too.
What exactly are you looking for?
A.
esys-intel
Quoting - ArturGuzik
mklinclude
A.
Precisely, i searchimport files (*.pas) to call librairy functions.
thanks
Lionel
ArturGuzik
thanks
Lionel
Well,
I'm not uware of any "ready" solution for that. I think you need to follow (sometimes painfull) scenario calling external library (from object pascal). This means adjusting calling conventions (CDECL/STDCALL for MKL and Delphi fastcall??) and passing data.
A.
Gennady_F_Intel
Lionel,
MKL doesn't support such interfaces at all. As Artur mentine above, Intel MKL provides support for C and Fortran language interfaces.
--Gennady
ArturGuzik
Lionel,
--Gennady
Although I lost the touch with Delphi long, long time ago, I believe I saw somewhere that it supports (?) C# interfaces now. If this is correct, then a good start would be this KB article and trying to figure out how to do this in C#. The other option is just try to communicate (CDECL calling convention) dll (MKL here) with Delphi with an advantage that you have a full control on what's going on and no need for any wrappers etc.
A.
