MKL help with mkl_sparse_s_create_coo and MKL_SPARSE_CONVERT_CSR
Brandon_R_
I am trying to use mkl_spblas and I am having some strange issues. Firstly, here is the code I am trying to compile using mkl-16.2.181 and impi-intel-5.1.3-16.0.2.
MODULE test
contains
subroutine tester_sub(l,N,Pf)
use MKL_SPBLAS
include 'mkl_spblas.fi'
include 'mkl_sparse_handle.fi'
!declaring variables
integer, intent(in) :: l,N
integer, DIMENSION(1) :: seed = (/300/)
real :: num
real, dimension(4) :: sum1
real, dimension(2) :: sum2
real :: hf,hc,U,Z
real, intent(out) :: pf
integer :: i,nf,nc,N1
real, allocatable, dimension(:) :: cf_m,cfd,cf_p,cf,cc_m,ccd,cc_p,cc,RHS,ones_f,ones_c,uf,uc
integer, allocatable, dimension(:,:) :: coords_d, coords_m,coords_p
type (SPARSE_MATRIX_T) :: A0f,A1f,A0c,A1c,LHS,Identity_c,Identity_f,A1f_csr
integer :: stat
real, allocatable,dimension(:) :: cf_full,cc_full
type(MATRIX_DESCR) :: descr!SPARSE_MATRIX_TYPE_GENERAL
nf = 2**(l+1)
!creating a ones array for f
ALLOCATE(ones_f(nf-1))
ones_f = real(-1)
ALLOCATE(cf(nf),cf_m(nf-1),cfd(nf-1),cf_p(nf-1))
hf = real(1)/real(nf)
cf = real(1)
cf_m = hf**(-2)*cf(2:size(cf))
cfd = hf**(-2)*-cf(2:size(cf)) - hf**(-2)*cf(1:size(cf)-1)
cf_p = hf**(-2)*cf(1:size(cf)-1)
ALLOCATE(coords_d(nf-1,2))
ALLOCATE(coords_m(nf-1,2))
ALLOCATE(coords_p(nf-1,2))
!creating the coordinates of the vectors
do i = 1,nf-1
   coords_d(i,:) = i
end do
!don't want last row of matrix
do i = 1,nf-1
   coords_m(i,1) = i + 1     !row position
   coords_m(i,2) = i         !column position        end do
!don't want last row of matrix        do i = 1,nf-1
   coords_p(i,1) = i         !row position        coords_p(i,2) = i + 1     !column position        end do
allocate(cf_full(3*nf-3))
!holding all of the values for the sparse matrix
cf_full = (/ cf_m,cfd,cf_p  /)
stat = mkl_sparse_s_create_coo(A0f,1,nf-1,nf-1,size(cf_full),(/ coords_m(1:nf-2,1),coords_d(:,1), &
     coords_p(1:nf-2,1) /),(/ coords_m(1:nf-2,2),coords_d(:,2),coords_p(1:nf-2,2) /),cf_full)
print *, stat
print *, 'here 0'
stat = MKL_SPARSE_CONVERT_CSR(A0f,SPARSE_OPERATION_NON_TRANSPOSE,A0f)
print *, 'here 1'
end subroutine tester_sub
end MODULE test
I can compile the code so I believe that all of the libraries are linked correctly.
When I do print *, stat  after mkl_sparse_s_create_coo I get the value 3. I am unsure of what this value actually means. From https://software.intel.com/en-us/node/590112 it seems like mkl_sparse_s_create_coo is supposed to return a Character, but I can only use integer type for stat.
Once I try to use  MKL_SPARSE_CONVERT_CSR the program either has a segmentation fault or it hangs. I believe this is because A0f is not created correctly.
So, I guess my question is
1) What does stat = 3 mean?
2) If I am creating the sparse matrix A0f incorrectly, how do I create it correctly?
Zhen_Z_Intel
Hi Brandon,
You could check the enum value defined in mkl_spbals.f90 , the "status=3" represents invalid input value. Please make sure your type and value of input attributes. In your code, you indicate input array index from 1, row size and column size are 2^(I+1)-1, but what is the value of I? It might be the problem with... Here's an example called "sparse_s_csrmv.f90" in %MKLROOT%\examples\examples_core_f\spblasf\source, you could refer how function "mkl_sparse_s_create_csc" can be used. The function for creating matrix in csc format is similar to function of creating matrix in coo format, just change some attributes. Hope it could help you.
Fiona
Brandon_R_
Hello Fiona,
Since the last time we spoke, I have instead created sparse matrices A and B using the CSR format. I am still having some issues though. Here is the code where
                 |   1       2      0    0     0   |
                 |   0       3      4    5     0   |
  A    =         |   0       0      6    7     8   |
                 |   0       0      0    9     10  |
                 |   2       2      0    0     0   |
                 |   0       2      2    2     0   |
  B    =         |   0       0      2    2     2   |
                 |   0       0      0    2     2   |
! code start ***************************************************************************************************************
type (SPARSE_MATRIX_T) :: A,B,C
integer :: stat
real :: values_a(10),values_b(10),values_b_x(10)
integer :: col_a(10),col_b(10),row_start_a(5),row_start_b(5),row_end_a(4),row_end_b(4)
integer :: col_b_x(10),row_start_b_x(5),row_end_b_x(4)
integer :: rows, cols,indexing
values_a(1:10) = real((/1,2,3,4,5,6,7,8,9,10/))
values_b(1:10) = real((/2,2,2,2,2,2,2,2,2,2/))
col_a(1:10) = (/1,2,2,3,4,3,4,5,4,5/)
col_b(1:10) = (/1,2,2,3,4,3,4,5,4,5/)
row_start_a(1:5) = (/1,3,6,9,11/)
row_start_b(1:5) = (/1,3,6,9,11/)
row_end_a(1:4) = (/2,5,8,10/)
row_end_b(1:4) = (/2,5,8,10/)
stat = mkl_sparse_s_create_csr(A,SPARSE_INDEX_BASE_ONE,4,5,row_start_a,row_end_a,col_a,values_a)
print *, stat
stat = mkl_sparse_s_create_csr(B,SPARSE_INDEX_BASE_ONE,4,5,row_start_b,row_end_b,col_b,values_b)
print *, stat
stat = mkl_sparse_s_export_csr(B,indexing,rows,cols,row_start_b_x,row_end_b_x,col_b_x,values_b_x)
print *, stat
print *, row_start_b_x
stat = mkl_sparse_s_add(SPARSE_OPERATION_NON_TRANSPOSE,B,real(1.0),A,C)
print *, stat
! code end ***************************************************************************************************************
However, I get the following output:
           0
           0
           0
     7183776           0           0           0           0
           2
It seems like I am not creating the matrices correctly, but I believe I am. Printing stat, shows that creating A and B is
successful and that exporting the csr format is also successful, but adding the two matrices gives the error SPARSE_STATUS_ALLOC_FAILED.
What exactly is going on here?
Thank you,
Brandon
Zhen_Z_Intel
Hi Brandon,
You didn't assign value for variables "indexing", "rows" and "cols"...... Please check with your code. Thanks.
Fiona
Irina_S_Intel
Hi Brandon, Fiona,
Parameters  "indexing", "rows" and "cols" are output parameters and should not be assigned.
Brandon, I need some time to check your issue and see how we can help you.
Irina
Brandon_R_
Hello Irina,
Thank you very much for your help. Also, I was wondering if you could possibly try to run the program that I have implemented above? It might be possible that I am not correctly linked to the library.
Thank you,
Brandon
Irina_S_Intel
Hi Brandon,
Concerning the second problem with mkl_sparse_s_add, I run your code and see similar behavior. This issue will be fixed in future MKL releases, the problem is caused by incorrect behavior of mkl_sparse_s_export_csr. I can suggest you two workarounds:
  1. If it’s not possible, use C. If it is not possible:
  2. Add correct interface of mkl_sparse_s_export_csr in the beginning of your program, pass C pointers in the body of mkl_sparse_s_export_csr and cast them to fortran pointers afterwards. Here is an example how this can be done with the code that you’ve sent. Please let me know if you've succeeded in using such approach.
        PROGRAM test
	USE ISO_C_BINDING
        USE MKL_SPBLAS
       !Declare new interface with aarrays rows, cols, values of type C pointer
       !Change name of the routine to EXPORT_CSR_FIXED so it doesn’t conflict with existing MKL interface
        INTERFACE
            FUNCTION MKL_SPARSE_S_EXPORT_CSR_FIXED(source,indexing,rows,cols,rows_start,rows_end,col_indx,values) &
                 BIND(C, name='MKL_SPARSE_S_EXPORT_CSR')
            USE, INTRINSIC :: ISO_C_BINDING , ONLY : C_INT, C_FLOAT, C_PTR
            IMPORT SPARSE_MATRIX_T
            TYPE(SPARSE_MATRIX_T), INTENT(IN) :: source
            INTEGER(C_INT)      , INTENT(INOUT) :: indexing
            INTEGER(C_INT)      , INTENT(INOUT) :: rows
            INTEGER(C_INT)      , INTENT(INOUT) :: cols
            TYPE(C_PTR)         , INTENT(INOUT) :: rows_start
            TYPE(C_PTR)         , INTENT(INOUT) :: rows_end
            TYPE(C_PTR)         , INTENT(INOUT) :: col_indx
            TYPE(C_PTR)         , INTENT(INOUT) :: values
            INTEGER(C_INT) MKL_SPARSE_S_EXPORT_CSR_FIXED
            END FUNCTION
        END INTERFACE
        integer :: stat
        !declare C and fortran pointers. C pointers will be passed to the body of export_csr routine.
        integer nnz, nrows
        type(c_ptr) :: row_start_c, row_end_c, col_c, values_c
        integer, pointer, dimension(:) :: row_start_f, row_end_f, col_f
        real, pointer, dimension(:) :: values_f
        values_b(1:10) = real((/2,2,2,2,2,2,2,2,2,3/))
        stat = mkl_sparse_s_create_csr(A,SPARSE_INDEX_BASE_ONE,4,5, &
        print *, stat
        stat = mkl_sparse_s_create_csr(B,SPARSE_INDEX_BASE_ONE,4,5,&
        print *, stat
        stat = mkl_sparse_s_add(SPARSE_OPERATION_NON_TRANSPOSE,&
        B,real(1.0),A,C)
        !call export_csr with C pointers
        stat = mkl_sparse_s_export_csr_fixed(C,indexing,rows,cols,&
        row_start_c,row_end_c,col_c,values_c)
        print *, stat
        print *, 'rows ', rows
        print *, 'indexing', indexing
        nrows = rows
        !Cast C pointers that came from export routine to Fortran pointers
                        call c_f_pointer(row_start_c, row_start_f, [nrows+1])
        call c_f_pointer(row_end_c, row_end_f, [nrows])
        nnz = row_start_f(nrows+1)-indexing
        print *, nnz
        call c_f_pointer(col_c,     col_f,     [nnz])
        call c_f_pointer(values_c,   values_f,   [nnz])
        print *,'row_start_f', row_start_f
        print *,'row_end_f', row_end_f
        print *,'col_f', col_f
        print *,'values_f', values_f
        print *, stat
        END PROGRAM test
