MKL in Xcode
Raph
I'm in the process of transitioning from a PPC Mac and xlf to an Intel Mac and ifort. I have managed to transfer over an XCode project, fix the compiler and options and get one program to compile. So I'm pretty sure I have the basics down.
However, another executable in the same project, which unlike the first program links against MKL's LAPACK, does not compile. I can compile and run the same execuatable using Make on the command line, so I'm pretty sure the problem is in configuring the build in XCode.
I'm using Xcode 3.1, MKL 10.0.4.022 and ifort 10.1.017.
Here's what I've done.
1) Added Intel_MKL.framework to the "Link Binary with Libraries".
2) Under build in the Get Info box, I set
LIBRARY_SEARCH_PATHS = /Library/Frameworks/Intel_MKL.framework/Versions/Current/lib/em64t/
USER_HEADER_SEARCH_PATHS = /Library/Frameworks/Intel_MKL.framework/Headers/**
OTHER_LDFLAGS = -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -lguide
I get the following error
ipo: warning #11023: file format not recognized for /Library/Frameworks/Intel_MKL.framework/Versions/Current/lib/em64t/libmkl_intel_lp64.dylib
ipo: warning #11023: file format not recognized for /Library/Frameworks/Intel_MKL.framework/Versions/Current/lib/em64t/libmkl_sequential.dylib
ipo: warning #11023: file format not recognized for /Library/Frameworks/Intel_MKL.framework/Versions/Current/lib/em64t/libmkl_core.dylib
ipo: warning #11023: file format not recognized for /Library/Frameworks/Intel_MKL.framework/Versions/Current/lib/em64t/libguide.dylib
IPO link: can not find -framework Intel_MKL
ifort: error #10014: problem during multi-file optimization compilation (code 1)
Build failed (2 errors, 6 warnings)
Any ideas what I've forgotten to do?
Raph
AndrewC
New Contributor III
Sounds like you are building a 32-bit XCode target, but linking against the 64-bit MKL.
Raph
Quoting - vasci_intel
I finally got back to this problem.
How to I build a 64 bit XCode target? The "Architectures" setting is set to "Native Architecture of Build Machine" on this MacBook. The code compiles, links and runs fine with Make on this machine (see below), so I'm pretty sure 64 bit is the right libraries to use.
Raph
% make xnet
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -c data.f
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -c ffn.f
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -c full_net.f
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -c match.f
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -c flux.f
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -c net.f
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -c eosnom90.f
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -c jacobian_dense.f
ifort -pg -ipo -O3 -xT -mdynamic-no-pic -no-prec-div -autodouble -g -o xnet data.o ffn.o full_net.o match.o net.o flux.o eosnom90.o jacobian_dense.o -I/Library/Frameworks/Intel_MKL.framework/Versions/Current/include -L/Library/Frameworks/Intel_MKL.framework/Versions/Current/lib/em64t -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lmkl_sequential -lmkl_core -lguide
ipo: remark #11000: performing multi-file optimizations
ipo: remark #11005: generating object file /var/folders/EH/EHnPHq7RHA4K3TDOT18kbI2wqow/-Tmp-/ipo_ifortgVCULX.o
Andrey_Bespalov
Could you add -V to ifort's options to see exactly which version of compiler is used?
Raph
Adding -V to the loader in the Makefile adds
Intel Fortran Compiler for applications running on Intel 64, Version 10.1 Build 20080801 Package ID: m_fc_p_10.1.017
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
and
@(#)PROGRAM:ld PROJECT:ld64-85
Library search paths:
/Library/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/lib/em64t
/opt/intel/fce/10.1.017/lib
/usr/lib/i686-apple-darwin9/4.0.1/
/usr/lib/
/Library/Frameworks/Intel_MKL.framework/Versions/10.0.5.025/lib/em64t/
/usr/lib/gcc/i686-apple-darwin9/4.0.1/x86_64
/usr/lib
/usr/lib
/usr/local/lib
Framework search paths:
/System/Library/Frameworks/
I'm not sure how to do this in XCode.
Raph
Quoc-An_L_Intel
You canadd -V in Xcode by ->
get info -> build tab -> Intel Fortran Compiler 11.1 -> Additonal options
post the build log.
