MKL interval_arithmetic module
g_f_thomas
I'm using interval_arithmetic as in
program main
use interval_arithmetic
implicit none
type
(D_INTERVAL) :: A, sumA
!Initialization stuff here
sumA = dinterval(zero, zero)
doj = 1, lda
do i = 1, lda
sumA = sumA + ABS(A(i,j))
enddo
enddo
Why is ABS, which is interfaced in the interval_arithmetic module, not recognized as such? The linker issues:
error LNK2019: unresolved external symbol _DI_ABS referenced in function _MAIN__
Gerry
Todd_R_Intel
Indeed, I only see entry points for _D_ABS. I'll look into this.
-Todd
Vladimir_Koldakov__I
New Contributor III
Gerry,
There is workaround. Replace, please, name DI_ABS with D_ABS in the file include/mkl_interval.f90.
The same for SI_ABS. Here is diffs:
INTERFACE ABS
- FUNCTION SI_ABS(X)
+ FUNCTION S_ABS(X)
TYPE S_INTERVAL
REAL(4) :: INF, SUP
END TYPE S_INTERVAL
TYPE(S_INTERVAL), INTENT(IN) :: X
- TYPE(S_INTERVAL) :: SI_ABS
- END FUNCTION SI_ABS
+ TYPE(S_INTERVAL) :: S_ABS
+ END FUNCTION S_ABS
- FUNCTION DI_ABS(X)
+ FUNCTION D_ABS(X)
TYPE D_INTERVAL
REAL(8) :: INF, SUP
END TYPE D_INTERVAL
TYPE(D_INTERVAL), INTENT(IN) :: X
- TYPE(D_INTERVAL) :: DI_ABS
- END FUNCTION DI_ABS
+ TYPE(D_INTERVAL) :: D_ABS
+ END FUNCTION D_ABS
END INTERFACE
Vladimir
