MKL license
Sergey_F_1
I've got academic license for MKL, but we produce also commercial software in witch I would like to use MKL (only Redistributions). Can I use it free or must pay for additional license? If the last, can I buy only Redistributions​, cause I don't need your compilers (I use Delphi)?
Gennady_F_Intel
Sergey, in this case you have to purchase the commercial license. I will joint you with our business development manager via separate email to give your some steps you need to do.
Gerardo_G_
Hi
I know this is out of the post’s scope but I noticed you (the original poster) are using Delphi. I’ve been trying to link a simple console application to the MKL SDL but I haven’t managed to succeed yet (I’m not an expert on Delphi). Anyway, I’m trying to use MKL PARDISO but I don’t get any results, the output vector is not modified after calling the function. In my limited experience, I believe there must be a problem in the way I’m loading the function from the SDL. Below I have included the code I’m using to declare the function and also part of the console application code (I’ve left a lot of stuff out just to save space). In this example if I don’t initialize “x”, I get all zeros but if I do, the vector is not changed. Any help will be much appreciated (sorry to post this here but other delphi related posts are over 5 years old and I don't know if it's worth to create a new post just for this).
unit IntelMKL;
interface
uses
  Windows,
  Wintypes,
  WinProcs,
  SysUtils,
  Classes;
function PARDISO(var pt:array of Pointer; var maxfct, mnum, mtype, phase, n:Integer; var a:array of Double; var ia,ja:array of Integer; var perm, nrhs:Integer; var iparm:array of Integer; var msglvl:Integer; var b: Array of Double; var x: Array of Double; var error:Integer): Pointer; stdcall; external 'mkl_rt.dll' name 'PARDISO';
function MKL_Set_Num_Threads_Local(nt: Integer): Integer; stdcall; external 'mkl_rt.dll' name 'MKL_Set_Num_Threads_Local';
function MKL_Set_Num_Threads(nt: Integer): Pointer; stdcall; external 'mkl_rt.dll' name 'MKL_Set_Num_Threads';
function MKL_Set_Dynamic(nt: Integer): Pointer; stdcall; external 'mkl_rt.dll' name 'MKL_Set_Dynamic';
implementation
end.
var
 a,b,x,ddum: array of Double;
 ia,ja,iparm: array of Integer;
 pt : array of Pointer;
 n, mtype, nrhs, maxfct, mnum, phase, error, msglvl, idum, i, nthreads, dynthreads: Integer;
begin
  setLength(a,18);
  setLength(ja,18);
  setLength(ia,9);
  setLength(b,8);
  setLength(x,8);
  setLength(ddum,1);
  setLength(pt,64);
  setLength(iparm,64);
  phase := 13;
  PARDISO(pt, maxfct, mnum, mtype, phase, n, a, ia, ja, idum, nrhs, iparm, msglvl, b, x, error);
  for i := 1 to n do
      Writeln('x['+IntToStr(i-1)+'] ='+FloatToStr(x[i-1]));
end
Gerardo
Sergey_F_1
Hello!
I have used only simple LAPACK functions of 1-3 level. All of them work fine exclude ones with wml extension (now I try to solve the problem). If you are interested in this point I can send you some examples.
Gerardo_G_
It would be nice if you could send me your examples. I've been trying other stuff, like defining all function parameters as pointers (I saw someone do it in an example) but haven't made any progress. Thanks in advance for your help!
Sergey_F_1
Not earlier then on Tuesday (little vacation).
Gerardo_G_
Sure, no problem! Enjoy your vacation.
Sergey_F_1
//If You need more examples, please let me now.
unit MKL1;
interface
const IntelDLL = 'mkl_intel_thread.DLL' ;
procedure saxpy(var n:int64; var alpha:single; var x:single; var incx:int64; var y:single; var incy:int64); CDecl ;
implementation
procedure saxpy ; CDecl ; external IntelDLL name 'mkl_blas_saxpy' ;
//Test: multiplication of array by 10.
// Tested for 64-bit applications;
// for 32-bit's you should somewhere use "integer" type instead of "int64" (change if doesn't work).
// For both it's possible to use conditional compilation with symbol "win64"
  var
      i,N,incx:int64;
      X:single;
      A,Y:array[1..100] of single;
  begin
  N:=100; incx:=1;
  for i:=1 to N do A:=i; X:=10;
  saxpy(N,X,A[1],incx,Y[1],incx);
  end.
Gerardo_G_
Thanks for the example! I managed to make mine work based on yours. Thanks again, you are a real lifesaver.
Sergey_F_1
I'm very glad to help you :)
