MKL might not support my platform!!
malik__tania
Hi
I installed Fupermod software framwork with MKL it installed correctally but when I run my application i got this error:
tania@tania-Latitude-E5540:~/openform_fupermod_test$ mpirun -np 6 -machinefile machinefile ~/build_fupermod/mkl/tools/builder -l ~/build_fupermod/mkl/routines/mxm/.libs/libmxm_1d.so -U2000 -s100
Kernel:/home/tania/build_fupermod/mkl/routines/mxm/.libs/libmxm_1d.so
Intel MKL FATAL ERROR: Cannot load libmkl_avx2.so or libmkl_def.so.
Primary job  terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
  Process name: [[32927,1],2]
  Exit code:    2
I posted about this error in this thread. But still didn't get any solution.
https://software.intel.com/en-us/comment/1853675#comment-1853675
 Here is my platform description.
tania@tania-Latitude-E5540:~/openform_fupermod_test$ lscpu
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                4
On-line CPU(s) list:   0-3
Thread(s) per core:    2
Core(s) per socket:    2
Socket(s):             1
NUMA node(s):          1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 69
Stepping:              1
CPU MHz:               1399.992
BogoMIPS:              5387.86
Virtualization:        VT-x
L1d cache:             32K
L1i cache:             32K
L2 cache:              256K
L3 cache:              4096K
NUMA node0 CPU(s):     0-3
I run MKL example cblas it works properly. Here is the output
tania@tania-Latitude-E5540:/opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/examples/cblas$ sudo make libintel64 function=cblas_dgemm compiler=gnu
make cblas_dgemmx.res  _IA=intel64 EXT=a RES_EXT=lib
make[1]: Entering directory `/opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/examples/cblas'
mkdir -p ./_results/gnu_lp64_parallel_intel64_lib
gcc    -m64 -w -I../../include source/cblas_dgemmx.c source/common_func.c  -Wl,--start-group "../../lib/intel64"/libmkl_intel_lp64.a "../../lib/intel64"/libmkl_intel_thread.a "../../lib/intel64"/libmkl_core.a -Wl,--end-group -L"../../../compiler/lib/intel64" -liomp5 -lpthread -ldl -lm -o _results/gnu_lp64_parallel_intel64_lib/cblas_dgemmx.out
Here you can see with simple c program, I also checked linking it has no issue.
tania@tania-Latitude-E5540:/tmp$ gcc -o test test.c -L/opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/lib/intel64_lin -lmkl_avx2 -lmkl_def
tania@tania-Latitude-E5540:/tmp$ ./test
tania@tania-Latitude-E5540:/tmp$ mpicc -o test test.c -L/opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/lib/intel64_lin -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_sequential -lmkl_core
tania@tania-Latitude-E5540:/tmp$ mpicc -fopenmp -o test test.c -L/opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/lib/intel64_lin -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_sequential -lmkl_core -lgomp
tania@tania-Latitude-E5540:/tmp$ mpicc -O0 -fopenmp -o test test.c -L/opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/lib/intel64_lin -lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_sequential -lmkl_core -lgsl -lgslcblas -ldl -lm -lrt -lgomp -pthread
Now I am sure there is some problem with MKL with my platform. As it ask for the ibmkl_avx2.so or libmkl_def.so. Although the path includes these files. But I don't know why I am getting this error. Plz help me. And plz let me know, If it is a bug in MKL how can I report it?
Roman_D_Intel1
Hi Tania,
1) Does your app run fine if executed without mpirun?
2) Could you please print the contents of LD_LIBRARY_PATH before running the program?
3) Which mpi do you use? If Intel's, could you please add -genvall to mpirun's options?
malik__tania
Hi
(1) I got the same error without Mpirun
tania@tania-Latitude-E5540:~/openform_fupermod_test$ ~/build_fupermod/mkl/tools/builder -l ~/build_fupermod/mkl/routines/mxm/.libs/libmxm_1d.so -U2000 -s100
(2) Here is the output of echo $LD_LIBRARY_PATH
tania@tania-Latitude-E5540:~/openform_fupermod_test$ echo $LD_LIBRARY_PATH
/home/tania/.openmpi/lib/:/opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/lib/intel64_lin:/opt/ThirdParty-3.0.1/platforms/linux64Gcc/gperftools-svn/lib:/opt/paraviewopenfoam44/lib/paraview-4.4:/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/opt/ThirdParty-3.0.1/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/home/tania/.openmpi/lib:/home/tania/OpenFOAM/tania-3.0.1/platforms/linux64GccDPInt32Opt/lib:/opt/site/3.0.1/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib:/opt/ThirdParty-3.0.1/platforms/linux64GccDPInt32Opt/lib:/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib/dummy:/home/tania/.openmpi/lib/
Intel MKL FATAL ERROR: Cannot load libmkl_avx2.so or libmkl_def.so.Intel MKL FATAL ERROR: Cannot load libmkl_avx2.so or libmkl_def.so.
  Process name: [[56104,1],1]
  Exit code:    2
(3) I am using openmpi-1.10.1
Also when I install Fupermod with GSL . My application run perfactlly. Plus on grid5000 platform it works with MKL too, but not working on my laptop.
malik__tania
Here is the ldd output
tania@tania-Latitude-E5540:~/openform_fupermod_test$ ldd ~/build_fupermod/mkl/routines/mxm/.libs/libmxm_1d.so
    linux-vdso.so.1 =>  (0x00007ffcf9139000)
    libmpi_cxx.so.1 => /home/tania/.openmpi/lib/libmpi_cxx.so.1 (0x00007f2522ba4000)
    libmpi.so.12 => /home/tania/.openmpi/lib/libmpi.so.12 (0x00007f25228cf000)
    libmkl_intel_lp64.so => /opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/lib/intel64_lin/libmkl_intel_lp64.so (0x00007f2521f91000)
    libmkl_gnu_thread.so => /opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/lib/intel64_lin/libmkl_gnu_thread.so (0x00007f252120c000)
    libmkl_core.so => /opt/intel/compilers_and_libraries_2016.0.109/linux/mkl/lib/intel64_lin/libmkl_core.so (0x00007f251f927000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f251f621000)
    libgomp.so.1 => /usr/lib/x86_64-linux-gnu/libgomp.so.1 (0x00007f251f412000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f251f1fc000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f251efde000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f251ec19000)
    libopen-pal.so.13 => /home/tania/.openmpi/lib/libopen-pal.so.13 (0x00007f251e93b000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f251e637000)
    libibverbs.so.1 => /usr/lib/libibverbs.so.1 (0x00007f251e429000)
    libopen-rte.so.12 => /home/tania/.openmpi/lib/libopen-rte.so.12 (0x00007f251e1ad000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f251dfa9000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f2522fd7000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f251dda1000)
    libutil.so.1 => /lib/x86_64-linux-gnu/libutil.so.1 (0x00007f251db9e000)
Seems like libmkl_intel_lp64.so  or ibmkl_gnu_thread.so  or  libmkl_core.so internally invokes  libmkl_avx2.so or libmkl_def.so. Because in my application I don't need them directaly.
Ying_H_Intel
Hi Tania,
The libmxm_1d.so build looks fine.  You are exactly right, libmkl_intel_lp64.so  or ibmkl_gnu_thread.so  or  libmkl_core.so internally invokes  libmkl_avx2.so or libmkl_def.so( they are  processor-optimized library).  So the problem is the calling environment can't recognize the following Link Path.  Could you rebuild the libmxm_1d.so with static library? for example, you can link the libmkl_intel_lp64.a  libmkl_gnu_thread.a libmkl_core.a in your link line.
Then when ldd libmxm_1d.so, no mkl library needed.
Ying
malik__tania
Hi Ying
I have to build the libmxm_1d.so with dynamic library. Because I have to use MKL laibrary threading with this builder application. Is their any other option to make it fix please?
Ying_H_Intel
Hi Tania,
YOu can  build the libmxm_1d.so with threading MKL library,  whatever link with dynamic library and static library.  For example,   libmkl_intel_lp64.a  libmkl_gnu_thread.a libmkl_core.a + dynamic gomp library are static library and GNU openmp threading.
If have to use threading MKL library, you may need to add -rpath option and -Wl -as-no-needed option in your build link.  as I mentioned last time.
Ying
