MKL multithreading - why do I not see all threads in "top" command ?
miro_ilias
Dear experts,
my small project scales well with  MKL_NUM_THREADS, see https://github.com/miroi/mathlibs-tester/blob/master/performance/results.rst  .
However, when running multithreaded run, (MKL_NUM_THREADS > 1), I do not see all threads printed in the "top" command. I see there only one process, the example executable.
Please is it possible to observe all the mkl-threads ? The project is https://github.com/miroi/mathlibs-tester .
Operating system is Linux lxir073 3.2.0-4-amd64 #1 SMP Debian 3.2.81-1 x86_64 GNU/Linux.
TimP
Versions of top which default to a single entry per multithreaded process have an option to expand by threads.
miro_ilias
Aaah, I see. That's the "H" key, and I see threads in top . Thanks a lot.
