7303 Discussions
MKL problems running vslzCorrExec1D, cross correlation.
Serjio
I can't run vslzCorrExec1D because I get status=-2303 or -2302.
Here is my code:
    // Creating input and output vetcors
    std::vector<std::complex<double>> x, y, z;
    x.resize(5);
    y.resize(5);
    z.resize(2*std::max(x.size(),y.size()) - 1);
    // Starting MKL cross correlation
    VSLCorrTaskPtr task;
    int status = 0;
    int iy0 = y.size() - 1;
    status = vslzCorrNewTask1D(&task, VSL_CORR_MODE_AUTO, y.size(), x.size(), z.size());
    status = vslCorrSetStart(task,&iy0);
    status = vslzCorrExec1D(task, (MKL_Complex16*)y.data(), xyz_indx, (MKL_Complex16*)x.data(), xyz_indx, (MKL_Complex16*)z.data(), xyz_indx);
Where are errors?
VidyalathaB_Intel
>>Where are errors?
Could you please try changing the below line as follows?
to
int iy0 = -(y.size() - 1);
Please refer to the below link for details about the start parameter while using the vslCorrSetStart routine.
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/statistical-functions/convolution-and-correlation/convolution-and-correlation-task-editors/vslconvsetstart-vslcorrsetstart.html#vslconvsetstart-vslcorrsetstart
Please try running your code with the above changes and do let us know if it resolves your issue. If not, please provide us a complete reproducer with oneMKL version and your OS details so that we can work on it from our end.
Vidya.
VidyalathaB_Intel
>>Where are errors?
to
Vidya.
Serjio
dear Vidya, after your suggestion my code works without any errors
int iy0 = -(y.size() - 1); // it works
Thank you.
VidyalathaB_Intel
Thanks for accepting our solution.
As your issue is resolved we are closing this thread.
If you need any additional assistance from Intel please post a new question as this thread will no longer be monitored.
Have a Nice Day!
Vidya.
