7303 Discussions
MKL problems when creating dll for Labview
loscermos
hi,
I have following problem
I'm trying to create a .dll containing Lapack functions from IMKL undeer VC++ 6 for Labview 7.1
I'm able to compile/create dll without any error but when using for some functions from LAPACK I'am recieving an error mesage when connceting dll to .vi saying that he couldn't find libiomp5md.dll.
For exaple when using in C++ coce func:
dgeqr2( &m, &n, a, &lda, b, work, &info ); Labview has no problems but for
dgeqp3( &m, &n, a, &lda, jpvt, tau, work, &lwork, &info ); or dgels()... I'am recieving the error code
in project I'm using following lib. as External dependencies:
mkl_intel_c.lib
mkl_intel_thread.lib
mkl_core.lib
libiomp5md.lib
Thanks for Help
Peter
Vladimir_Lunev
Quoting - loscermos
hi,
mkl_intel_c.lib
mkl_core.lib
libiomp5md.lib
Thanks for Help
Peter
Hello Peter,
As far as I see, DLL was successfully built but you have a problem at runtime: the system couldn't find libiomp5md.dll when you run your application.
Please check the presence of the directory ia32bin in the environment variable PATH. MS Visual Studio has the suitable control to add the directory to PATH in your project.
Note, some MKL functions require libiomp5md.dll but others do not require. Therefore Labview has no problem with dgeqr2, but system is reporting the error when you make a call to dgeqp3.
-Vladimir
loscermos
Hello Peter,
-Vladimir
Thanks, it worked:) (added ia32bin in windows env. variable)
Peter
