7287 Discussions
MKL "only" twice faster on a 8-Cores Machine
dar_io
Hello!
I wrote a Conjugate Gradient solver to solve big sparse systems and I parallelized it with SSE and OpenMP.
I'm working on a 8-Cores Mac Pro, and I reached a speedup of 9.0x in some cases (wrt to my non-parallel implementation).
I would compare my results with MKL so I used the dcg_init, dcg_check, dcg and dcg_get methods to solve my system.
For the crucial part of the Conjugate Gradient (the sparse matrix vector multiplication) I used the mkl_dcsrmv method.
I set the environment variable OMP_NUM_THREADS to 8 in my shell and I checked with a profiler that all the 8 cores were working 100%. Unfortunately, with MKL I have a speedup of "only" 2.0x (wrt to MKL working serially).
The matrix of my problem is square and sparse with ~2400000 non-zero elements and ~35000 rows.
Am I doing something wrong, am I forgetting something? Or, is the size of my problem to small to see big performance improvement with MKL?
Thanks in advance!
Best!
dario
TimP
Sparse matrix multiplication typically is memory bandwidth limited, with a high cache miss rate. In such cases, you may find that performance saturates at 2 or 4 threads. You should test the KMP_AFFINITY environment variable settings, KMP_AFFINITY=compact (or scatter). compact and scatter are likely to be the same, except at 4 threads.
It may be that disabling second/alternate sector prefetch could improve performance. I don't have access to Mac specific information on this. A few platforms may have a BIOS setup option. Without that, on linux, it involves root privilege, and an application to alter MSR (model specific register) settings.
dar_io
Thank you very much for your answer!
I will check and redo the tests with your advices!
Googling a bit, I discovered that "...thread affinity can have a dramatic effect on the application speed" (from intel.com).
Best,
dario
