MKL running in parallel on a server with two processors
bubai_l_
Hello everyone.
I have one server with two processors. Every processor has 16 cores. I found that MKL routines such as DGEMM can only run on one processor. I want that the MKL can employ all computing resource, i.e. two processors and 32 cores. How can I deal with this problem?
Thank you very much!
Ying_H_Intel
Hi Bubai
Could you please tell the processor type of the server  and the matrix size of dgemm?
According to MKL user guide : https://software.intel.com/en-us/node/528369
By default, Intel MKL uses the number of threads equal to the number of physical cores on the system. If your processor is Hyper Threading, (logical core is on), then it may only use the physical cores.
Ying
Ying_H_Intel
Hi Bubai
Ying
bubai_l_
Ying H (Intel) wrote:
Hi Bubai
Ying
Hi! Thank you very much! The problem has been solved with your help. Just like what you said, my processor is Hyper Threading and Intel MKL uses the number of threads equal to the number of physical cores. Thank you very much again!
