MKL's dependency on gcc and glibc
Fu_J_Intel
HI,
what is MKL's dependency on gcc and glibc?
thanks,
Jeffrey
Gennady_F_Intel
you may have a look at the mkl's system requirements - Supported C/C++ compilers for Linux : https://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-2017-system-requirements
Fu_J_Intel
Hi Gennady,
redhat EL6 is in the list of supported OS.  Does it mean centos 6.5 should also work with MKL?  My main concern is if gcc 4.4.7 works with MKL?
- Jeffrey
TimP
Yes, CentOS 6 "should work," but likely hasn't been tested as fully as Red Hat.  It may require you to accept unsupported OS during installation.
Fu_J_Intel
Hi Tim and Genenady,
thanks for comments.
to be clear, my main concern is "what is the requirement of gcc for mkl-dnn?".    I heard mkl-dnn requires at least gcc 4.8.x.  Is that true?
thanks,
Jeffrey
TimP
I see that gcc 4.9 is suggested if you don't use an Intel compiler. It's certainly possible to install a newer gcc in addition to your system compiler.
Fu_J_Intel
where is gcc 4.9 mentioned?
in (https://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-2017-syste-requirements),  I do not see any requirement of gcc.
