does mkl-dnn require c++11 compiler
Fu_J_Intel
does mkl-dnn require c++11 compiler?
thanks,
Jeffrey
Zhen_Z_Intel
Hi Jef,
I don't think the MKL DNN require C++ 11, you could implemented by C code, it's might not related on C++ standard.
Fiona
Evarist_F_Intel
MKL-DNN does not require neither C++ compiler nor C++ runtime. You may use its C interface.
Though for simplicity MKL-DNN has C++11 wrappers distributed in header form (mkldnn.hpp), which provide much more sophisticated interface. Of course in order to use this wrappers you need compiler with C++11 support.
