7298 Discussions
MKL warning #11009: file format not recognized?
davidspurr
Hi
I keep getting the following warning message when compiling a particular program (does use MKL):
1>ipo: warning #11009: file format not recognized for mkl_c.lib
As far as I can tell it is not causing any problems. I only use MKL for some random number options (eg. VSL_BRNG_SOBOL, VSL_BRNG_MRG32K3A etc). As far as I am aware, it is only working on array data, so it's not clear why the "file format" reference.
OK to ignore?
FWIW I do not have IMSL or other such libraries installed
(w_cprof_p_11.0.061, MKL 10.1.0.018)
ArturGuzik
Valued Contributor I
check this thread, maybe you can find some hints there.
A.
davidspurr
Thanks. I had seen that thread but thought it was probably sufficiently different to warrant a separate enquiry.
ArturGuzik
I'm always confused by the version(s) and their options, but maybe you can (version OK?) just replace mkl_c with mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib, what will be required anyway, when you upgrade to version 10.2.
A.
