Matrix Inversion Using Intel MKL
Debanjan_Mukherjee
I am trying to write a simple matrix inversion routine in Ubuntu 64 bit. I modified one of the MKL example codes as follows:
program inversion
use mkl95_lapack, only: getrf, getri
implicit none
integer:: I, N
integer, dimension(:), allocatable:: IPIV
double precision, dimension(:,:), allocatable:: A, AA
N = 3
allocate( IPIV(N) )
allocate( A(N,N), AA(N,N) )
AA(1,1) = 1.0d0; AA(1,2) = 3.0d0; AA(1,3) = 1.0d0
AA(2,1) = 1.0d0; AA(2,2) = 1.0d0; AA(2,3) = 2.0d0
AA(3,1) = 2.0d0; AA(3,2) = 3.0d0; AA(3,3) = 4.0d0
A = AA
write(*,*) 'The Matrix A is:'
do I = 1,N
write(*,*) AA(I,:)
end do
write(*,*) 'The First Step is to Factorise A'
call getrf( A, IPIV )
write(*,*) 'The Inverted Matrix is:'
do I = 1,N
write(*,*) A(I,:)
end do
write(*,*) 'The Second Step is to Invert A'
call getri( A, IPIV )
do I = 1,N
write(*,*) A(I,:)
end do
end program inversion
I keep getting an error message saying: error #6285: There is no matching specific subroutine for this generic subroutine call. [GETRI]
I am pretty new to using MKL templates for applications, and I was wondering if someone could throw some pointers as to what is happening. My link-line during compilation is as follows:
ifort inversion.f90 -I/opt/intel/mkl/include/intel64/ilp64 -L/opt/intel/mkl/lib/intel64/ -lmkl_lapack95_ilp64 -lmkl_blas95_ilp64 -lmkl_intel_ilp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread -o inversion.out
Any help or tips would be great for this newbie !! :)
Debanjan_Mukherjee
I must add - the above program with the corresponding library linking worked perfectly fine in 32 bit environment Ubuntu.
TimP
Then why did you link the ilp64 libraries, when the lp64 libraries are the ones for 32-bit (default) integers? Did you check whether your chosen copy of the USE .mod files wants 32- or 64-bit integers?
Chao_Y_Intel
As Tim suggest, the LP64 libraries should be the choice. The following post may help to provide some clarification on the difference:
http://software.intel.com/en-us/forums/showthread.php?t=83366
Chao
Debanjan_Mukherjee
Many thanks. I used the LP64 libraries and it worked. In reponse to the message on using ILP64 - I was actually confused since I had initially written and run the code in Ubuntu 32 bit machine, and then had to include it in a job to be run in a 64 bit machine - hence I ended up wrongly linking ILP64.
Many thanks again
