7298 Discussions
Memory leaks while using Intel MKL DSS subroutines
vijay1
I am using Intel MKL DSS subroutines to solve a sparse symmetric matrix. Attached is the sample program that I ran. I get memory leaks at the end of the application run. Do I need to use some function in addition to dss_delete() to clean up memory used by DSS subroutines. Please help!
Vijay
* Content : MKL DSS C example
** Example program to solve symmetric positive definite system of equations.
#include
#include
#include
#include
#include
#include
#include
#include
using namespace std;
#include "mkl_dss.h"
#include "mkl_types.h"
** Define the array and rhs vectors
#define NROWS 5
#define NCOLS 5
#define NNONZEROS 9
#define NRHS 1
static const MKL_INT nRows = NROWS;
static const MKL_INT nCols = NCOLS;
static const MKL_INT nNonZeros = NNONZEROS;
static const MKL_INT nRhs = NRHS;
static _INTEGER_t rowIndex[NROWS + 1] = { 1, 6, 7, 8, 9, 10 };
static _INTEGER_t columns[NNONZEROS] = { 1, 2, 3, 4, 5, 2, 3, 4, 5 };
static _DOUBLE_PRECISION_t values[NNONZEROS] =
{ 9, 1.5, 6, .75, 3, 0.5, 12, .625, 16 };
static _DOUBLE_PRECISION_t rhs[NCOLS] = { 1, 2, 3, 4, 5 };
MKL_INT
main ()
#ifdef _DEBUG
_CrtMemState MemState;
_CrtMemCheckpoint(&MemState);
// Use this method to check for memory leaks:
// If you get the following leak message upon closing the app:
// {204} normal block at 0x002F5610, 24 bytes long.
// Data: < c/ Xb/ d/ > 08 63 2F 00 58 62 2F 00 10 64 2F 00 CD CD CD CD
// Then you should call:
//_CrtSetBreakAlloc(4872L);
//_CrtSetBreakAlloc(1000);
//_CrtSetBreakAlloc(3411);
_CrtSetBreakAlloc(215);
#endif
MKL_INT i;
/* Allocate storage for the solver handle and the right-hand side. */
_DOUBLE_PRECISION_t solValues[NROWS];
_MKL_DSS_HANDLE_t handle;
_INTEGER_t error;
_CHARACTER_t statIn[] = "determinant";
_DOUBLE_PRECISION_t statOut[5];
MKL_INT opt = MKL_DSS_DEFAULTS;
MKL_INT sym = MKL_DSS_SYMMETRIC;
MKL_INT type = MKL_DSS_POSITIVE_DEFINITE;
/* Initialize the solver */
error = dss_create (handle, opt);
if (error != MKL_DSS_SUCCESS)
goto printError;
/* Define the non-zero structure of the matrix */
error = dss_define_structure (handle, sym, rowIndex, nRows, nCols,
columns, nNonZeros);
goto printError;
/* Reorder the matrix */
error = dss_reorder (handle, opt, 0);
goto printError;
/* Factor the matrix */
error = dss_factor_real (handle, type, values);
goto printError;
/* Get the solution vector */
error = dss_solve_real (handle, opt, rhs, nRhs, solValues);
goto printError;
/* Get the determinant (not for a diagonal matrix) */
if (nRows < nNonZeros)
error = dss_statistics (handle, opt, statIn, statOut);
goto printError;
/* print determinant */
printf (" determinant power is %g \\n", statOut[0]);
printf (" determinant base is %g \\n", statOut[1]);
printf (" Determinant is %g \\n", (pow (10.0, statOut[0])) * statOut[1]);
/* Deallocate solver storage */
error = dss_delete (handle, opt);
goto printError;
/* Print solution vector */
printf (" Solution array: ");
for (i = 0; i < nCols; i++)
printf (" %g", solValues);
printf ("\\n");
#ifdef _DEBUG
_CrtMemDumpAllObjectsSince(&MemState);
//_CrtDumpMemoryLeaks();
#endif
exit (0);
printError:
printf ("Solver returned error code %d\\n", error);
exit (1);
Gennady_F_Intel
this is the expected behaviour - please check with user's guide - "Using memory management"
Gennady_F_Intel
