Missing mkl_solver.lib
aw79
thinking that we have an IVF 10.1 Professional license with MKL and IMSL,
I was looking forward to test the performance of Pardiso (with the .f - example from the doc).
Unfortunately, the linker exits with
fatal error LNK1104: cannot open file 'mkl_solver.lib'.
Interestingly, I was not even trying to link mkl_solver.lib,
only imslmkl_dll.lib and mkl_c.lib. Searching for mkl_solver.lib gave no results.
So the question is whether we have a broken installation/wrong license to use Pardiso or
just wrong compiler/linker options? Thank you in advance
Anton
Gennady_F_Intel
Hello Anton,
I guess you are using MKL 10.* version? If yes, please try to link the following libraries for ia32 system:
mkl_solver.lib mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libguide40.lib
and let me know if any furher question
Regards, Gennady
Ushma_A_
Dear Sir,
I have installed Fortran composer_xe_2013_sp1.0.080. But the required mkl_solver.a library is not found in mkl/lib directory.
how it can be compiled.
mecej4
Use the MKL link-line advisor for the version of IFort and MKL that you have installed, instead of reading old third-party instructions on how to use older versions of MKL. Recent versions of MKL have the routines in the old solver library merged into the main MKL libraries.
You will find the link-line advisor in
     c:\Program Files (x86)\Intel\Composer XE 2013 SP1\Documentation\en_US\mkl\mkl_link_line_advisor.htm
Also see https://software.intel.com/en-us/articles/intel-mkl-link-line-advisor .
Gennady_F_Intel
as additionally you can use also Command-line Link Tool -  mkl_root\tools\mkl_link_tool.exe
