Multi-threaded PSSYEVD not threading actually
fabien_b_
Dear all,
When calling the SCALAPACK routine PSSYEVD with several threads, only the first MPI task is actually threading as expected.
I have met this issue on both my laptop and on a supercomputer, both running with MKL 2019.2.
In practice, the "top" command on my laptop when running with 2 MPI tasks and 2 MKL threads shows that the first MPI task runs at 200%, whereas the second one runs at 100%.
Note that this problem disappear when I call the double precision routine PDSYEVD instead or when I call the more regular PSSYEV.
Best,
Fabien
Gennady_F_Intel
actually this looks very strange because of our implementation is the same for single and double precision data types.
Am I understand you right that you run PSSYEVD executable on SMP machine and expect to see different threading based on top output?
fabien_b_
Let me be more precise. Here is why I do on my 4-core laptop:
> export OMP_NUM_THREADS=2
> export MKL_NUM_THREADS=2
> mpirun -np 2 ./a.out &
> top
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
15075 bruneval  20   0 2883124 422376  23480 R 198.7   2.6   0:21.94 a.out
15076 bruneval  20   0 1236508 237804  18008 R  99.7   1.5   0:11.64 a.out
The top shows two unbalanced MPI tasks. This is not what I expect. PDSYEVD would produce two tasks with 200% each.
Could someone reproduce this?
Best,
Fabien
