7263 Discussions
Newbie questions on Pardiso : allocate and initialize right-hand-side B and solution X, and sparse formatted B ?
canal_g_
Newbie to MKL/Pardiso. I was running my first program yesterday. Some quick questions on the right hand side B and solution X:
- is it correct that both B and X have to be allocated in every MPI process, and B must be set in every process also ?
- I am actually trying to get inverse of matrix, so the B is an identity matrix. But it seems that there is no way to specify B in a sparse format, in order to save memory. Is it true ?
thank you very much
canal
Gennady_F_Intel
allocation B and X will depends on iparm[39]. For example, in  the case if iparm[39]==2,  The solution vector, A, and RHS elements are distributed between processes in same manner. See documentation for more details.
lixin_c_
OIC, thank you
