Pardiso only uses 2 cpu cores out of 4
S__MPay
I am running a Pardiso solver but it only uses two cores out of 4 cores.
I read the documentations but I cannot find any solution.
I set windows environmental variables MKL_NUM_THREADS = 4 and OMP_NUM_THREADS = 4 but still number of OpenMP threads is 2.
I would appreciate if you could give me some hint on how to solve this problem?
TimP
You could look up your CPU at ark.intel.com (if it is an Intel CPU) to be certain that there are 4 cores.  If it is a 2-core CPU with HyperThreading, like the one I am using, the behavior you describe is the normal default, as using 4 threads is expected to be slower than 1 thread pinned to each core while taking advantage of your simd architecture.  If you wish to check it, read up on MKL_DYNAMIC setting.
TimP
