Non-square Matrix Transpose
Ioan_Hadade
Hi guys,
Are there any highly optimized MKL routines or maybe performance primitives that can do rectangle matrix transposition but without scaling?
I've been using mkl_omatcopy but it seems to perform worse than a normal baseline implementation and I suspect this is due to the additional scaling that is performed. I've attached a plot running a naive baseline implementation with comparison on omatcopy and imatcopy. The latter I know runs very poorly on non-square matrices.
I just want to know whether I should start spending some time optimizing my own transpose routine with AVX/AVX2 and blocking or whether there's a very efficient one out there already.
Also, swapping indices is not viable for what I am trying to achieve.
Thank you in advance!
Ioan
Gennady_F_Intel
Ioan,  Could you give us M x N sizes instead of the # of elements?
Ioan_Hadade
Hi Gennady,
Thanks for your reply. The transpositions I am performing are related to the dimension lifted transposition as seen in Henretty et al (http://repository.cmu.edu/cgi/viewcontent.cgi?article=1263&context=ece). Basically, it performs the required data layout organisation as to allow for aligned vector loads and stores of stencils in the x-direction path.
Anyway, I am basically transposing these large vectors into MxN arrays where N is always the SIMD register size which for this case is 4 as I am doing double precision. Therefore, on the graph, all matrix sizes will be MxN where M=no of element/veclen and N=veclen.
I guess this could be a cause for the poor performance due to gather and scatters? By the way, I am running this on a Xeon E5-2650 (Sandy Bridge).
The code looks something like this:
       // out of place MKL transposition
        mkl_domatcopy('r','t',VECLEN,NV,1,&q,NV,&qt,VECLEN);
        mkl_domatcopy('r','t',VECLEN,NV,1,&aux,NV,&auxt, VECLEN);
       roe_fluxes_xplane();
       // retranspose data back into original format for y-sweep of flucrd
        mkl_domatcopy('r','t',NV,VECLEN,1,&qt,VECLEN,&q,NV);
        mkl_domatcopy('r','t',NV,VECLEN,1,&auxt,VECLEN,&aux,NV);
So basically I need to transpose the data into the DLT format and then back again. Originally, the matrices will have a rectangle shape format, as they represent distinct blocks from a multiblock grid.
Thank you in advance for your kind consideration.
