Unexpected NaN with clbas_dgemm
Matt_S_
I am calculating a correlation matrix and am getting a weird issue. I have a 15x6 matrix R getting read into a subroutine correlation.c which calculates a 6x6 correlation matrix cor based off of the covariance matrix of R. My code looks like this
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include <mkl.h>
#include "params.h"
void show_matrix(REAL *A, int n_dim, int m_dim);
REAL *correlation(REAL *A, int n_dim, int m_dim)
   int diag;
   REAL *cvm = (REAL*)_mm_malloc(sizeof(REAL) * n_dim * n_dim, 64);
   REAL *cor = (REAL*)_mm_malloc(sizeof(REAL) * n_dim * n_dim, 64);
   REAL *colavg = (REAL*)_mm_malloc(sizeof(REAL) * n_dim, 64);
   if (cvm == NULL || colavg == NULL)
      printf("\nERROR: Cannot allocate memory for matrices in CORRELATION. Aborting...\n\n");
      exit(EXIT_FAILURE);
   else
      memset(cvm,0.0,sizeof(cvm));
      memset(cor,0.0,sizeof(cor));
      memset(colavg,0.0,sizeof(colavg));
   /* Calculate column averages */
   for (int i = 0; i < n_dim; i++)
      for (int j = 0; j < m_dim; j++)
         colavg += A[j * n_dim + i];
      colavg /= m_dim;
   /* Calculate covariance matrix */
   for (int i = 0; i < m_dim; i++)
      int indx = i * n_dim;
      for (int j = 0; j < n_dim; j++)
         A[indx + j] -= colavg;
   printf("A in\n");
   show_matrix(A, m_dim, n_dim);
   cblas_dgemm(CblasRowMajor, CblasTrans, CblasNoTrans, n_dim, n_dim, m_dim, 1.0, A, n_dim, A, n_dim, 1.0, cvm, n_dim);
   printf("cvm out\n");
   show_matrix(cvm, n_dim, n_dim);
         cvm[indx + j] /= (m_dim - 1);
   printf("cvm final\n");
   /* Calculate correlation matrix */
   diag = n_dim + 1;
      int idiag = i * diag;
      for (int j = 0; j <= i; j++)
         cor[indx + j] = cvm[indx + j] / sqrt(cvm[idiag] * cvm[j * diag]);
   printf("cor\n");
   show_matrix(cor, n_dim, n_dim);
   return cor;
The "A in" debug print gives my expected input of
A in
1.53400  1.53400  -1.53400  -1.53400  0.48900  -0.31900
-0.88700  -0.48900  0.88700  -0.88700  -0.15700  0.67400
-0.48900  0.67400  -0.48900  1.15000  1.53400  -0.48900
0.88700  0.00000  -0.67400  0.31900  -0.00000  -1.53400
1.15000  -0.31900  0.48900  0.67400  0.15700  1.15000
0.15700  -1.53400  -0.88700  -0.67400  -0.31900  0.15700
-1.15000  -0.67400  -0.15700  0.15700  -1.53400  -0.15700
0.00000  -0.88700  0.15700  -0.31900  -0.67400  0.88700
0.31900  -0.15700  0.67400  0.88700  0.67400  1.53400
-0.31900  0.15700  -0.31900  -1.15000  1.15000  -0.88700
-1.53400  0.88700  1.15000  1.53400  -0.48900  -1.15000
-0.15700  -1.15000  1.53400  -0.15700  -1.15000  -0.67400
0.48900  0.48900  -1.15000  0.48900  -0.88700  -0.00000
0.67400  0.31900  0.31900  0.00000  0.88700  0.31900
-0.67400  1.15000  0.00000  -0.48900  0.31900  0.48900
However the "cvm out" debug print gives something a little bit goofy
cvm out
10.56446  1.02348  -4.93052  -2.46705  2.76175  1.84661
1.02348  10.56446  -3.30580  0.74990  -nan  -2.39809
-4.93052  -3.30580  10.56446  3.56732  -2.08079  2.00943
-2.46705  0.74990  3.56732  10.56446  -0.43575  -0.31520
2.76175  5.11138  -2.08079  -0.43575  10.56446  0.55179
1.84661  -2.39809  2.00943  -0.31520  0.55179  10.56446
Why is that NaN there?! The symmetric value across the diagonal is correct! Very weird!
I am currently working around it by working only on the lower half, which works due to the matrix being SPD, but I'm very curious about this rogue NaN.
Any ideas?
Anthony_H_Intel1
Matt,
Using the same "A in" matrix and cblas_dgemm() call I was not able to reproduce the NaN. Note that I calculated "cvm" correctly only when "A" and "cvm" were of type double*. Can you provide any more information on the REAL type you are using? You might want try the same dgemm call with "A" and "cvm" as double* to see if it’s a type issue and if the NaN persists. Other than that, it would be helpful to know a little more about your environment: what MKL version are you using, are you using threading, what is your system/OS ... etc.
Anthony
Matt_S_
Anthony H. (Intel) wrote:
Matt,
Anthony
Anthony,
I have REAL defined in params.h (source below)
#ifndef _params_h
#define _params_h
#define REAL double /* precision of data */
#define DBG 0       /* 1 prints out results */
#define READIN 0    /* 1 reads in white paper data, 0 randomizes data */
#define NVAR 128      /* ncols */
#define NITER 25000    /* nrows */
#define RANDMIN -2
#define RANDMAX 2
#endif
And the matrix A is originally allocated by (in main)
REAL *r_data;
r_data = (REAL *)mkl_malloc(m_dim * n_dim * sizeof(REAL), 64);
memset(r_data,0.0,sizeof(r_data));
... /* setting of r_data values happens in here */
t_data = correlation(r_data, n_dim, m_dim);
and inside of correlation.c is where I get that NaN.
Anthony_H_Intel1
Hey Matt,
We tracked down the issue: the third parameter of memset() needs to specify the size of the matrix in addition to sizeof() so it should be
memset(cvm, 0.0, sizeof(cvm) * n_dim * n_dim);
Anthony
mecej4
That is still in error, and would cause you problems if you target x32 and x64; sizeof(cvm) and sizeof(*cvm) are not necessarily the same, depending on what REAL is defined to be; note that the count of bytes to set to zero should be computed from the size of each array element and the number of elements in the array, and the size of a pointer does not enter into this calculation.
Matt_S_
All,
That cleared it up, however this makes memset SLOW! Doing this is much faster and actually vectorizes according to the compiler (-qopt-report)
            matrix[indx + j] = 0.0;
