7302 Discussions
Not enough disk space error when installing on Yocto embedded Linux OS.
Rajaram_G_Intel
When running the install.sh script get the following error:
Error: not enough disk space in "/tmp" temporary directory. 100 MB is required for startup.
A df -h shows shows:
Filesystem   Size   Used   Available   Use%   Mounted on
tmpfs            1.9G  1.2M   1.9G          0%       /tmp
So there appears to be enough space in /tmp?
Also /tmp has rwx permissions for everyone.
Gennady_F_Intel
what package did you tried to install?
SergeyKostrov
Valued Contributor II
>>...Error: not enough disk space in "/tmp" temporary directory. 100 MB is required for startup... Intel software install scripts for Linux have an option that allows to specify a different directory for temporary files. Did you try it?
MKang3
I see the same problem. I changed the tmp path, but the error still shows:
S = "${WORKDIR}/l_mkl_2020.0.166/"
do_install () {
   install -d -m 755 ${D}/opt/intel
   install -d -m 755 ${D}/tmp
   ./install.sh -t ${D}/tmp
