OpenMP and FFT
mandrew
I am currently trying to take the FFTs of several functions using the following command:
DO i=1,N
Status = DftiComputeForward( Desc_Handle, f1(i,:))
Status = DftiComputeForward( Desc_Handle, f2(i,:))
Status = DftiComputeForward( Desc_Handle, f3(i,:))
Status = DftiComputeForward( Desc_Handle, f4(i,:))
END DO
Where I have used the following initializations:
Threads = 1
Status = DftiCreateDescriptor( Desc_Handle, DFTI_DOUBLE, &
DFTI_REAL, 1, M )
Status = DftiSetValue(Desc_Handle, DFTI_BACKWARD_SCALE, Scale)
Status = DftiSetValue(Desc_Handle, DFTI_NUMBER_OF_USER_THREADS, Threads)
Status = DftiSetValue(Desc_Handle, DFTI_PACKED_FORMAT, DFTI_CCS_FORMAT)
Status = DftiCommitDescriptor( Desc_Handle )
I would like to parallelize the the loop given above using OpenMP:
!$OMP DO
DO i=1,N
END DO
!$OMP END DO
However, I realize that this cannot work using the same Desc_Handle. Can anyone make a recommendation on how to treat the descriptor handle? In other words, what is the simplest way to parallelize the above loop using Intel's FFT functions?
Mandrew
Dmitry_B_Intel
Hi Mandrew,
Once single descriptor is to be shared between N user threads, the value of parameter DFTI_NUMBER_OF_USER_THREADS should be set to N. And the OpenMP loop should be limited to that number via num_threads(N) clause.
Dima
Gennady_F_Intel
Mandrew,
as an addition to Dima's comments, please look at the article "Different parallelization techniques for MKL FFT" by the following the link "http://software.intel.com/en-us/articles/different-parallelization-techniques-and-intel-mkl-fft/" See the example #4.
--Gennady
mandrew
Dima and Gennady:
Thanks for your help - it is now working great!
Mandrew
