PARDISO Linking Error
rlc138
Hi.
I have successfully linked to the pardiso library for a 32-bit application, but I cannot get a successful link for a 64-bit application. I am working with Microsoft Visual Studio 2008 (and have also been unsuccessful at building a 64-bit version using gcc-4.3.1 on a linux platform, which is ultimately where I am going with this).
For 32-bit I am linking with the following libraries (this works): mkl_solver.lib mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libguide40.lib
For 64-bit I am trying to link with the following libraries (this does not work):
mkl_solver_lp64.lib mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib libguide40.lib
The error message is:
1>Linking...
1>pardiso_unsym.obj : error LNK2001: unresolved external symbol pardiso_
1>pardiso_unsym.obj : error LNK2001: unresolved external symbol pardisoinit_
Both the linux and my desktop (windows) computershave Intel processors.
I suspect I am not including the correct libraries (or not including them in the correct order). Can someone please help?
Rob
ArturGuzik
Valued Contributor I
Quoting - rlc138
Hi.
1>Linking...
Rob
Rob,
the Linker Help suggests the following for 64:
mkl_solver_ilp64.lib mkl_intel_ilp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
and this works for me (VS2008, Fortran). You should also take a look at Gennady's page dealing with PARDISO.
A.
rlc138
Quoting - ArturGuzik
Rob,
A.
Thanks, but that does not work. I forgot to mention that I am working with C/C++ (for now just trying to compile the example pardiso_unsym.c). I am currently using MKL version 10.0.2.019 on my Windows machine and version 10.1.0.015 on Linux.
jaewonj
Quoting - rlc138
May work by replacing pardiso_ with PARDISO for MKL 10.1.
I believe pardisoinit is only available when linking against author's library not MKL.
http://www.pardiso-project.org/
Gennady_F_Intel
Quoting - rlc138
rlcampbell,
i checked the probelm but only with 10.0 update 4 version on win64 and with the pardis0_unsym and i didn't encountered the probelm.
see below how i did it:
set lib=C:appsintelMKL10.0.4em64tlib;%lib%
set path=C:appsintelMKL10.0.4em64tbin;%path
set include=C:appsintelMKL10.0.4include;%include%
icl /w /Fetestem64.exe pardiso_unsym_c.c mkl_solver_lp64.lib mkl_intel_lp64.lib mkl_intel_thread.lib mkl_core.lib libiomp5md.lib
pardiso_unsym_c.c
pardiso_unsym_c.c(87): (col. 2) remark: LOOP WAS VECTORIZED.
pardiso_unsym_c.c(90): (col. 2) remark: BLOCK WAS VECTORIZED.
pardiso_unsym_c.c(119): (col. 2) remark: LOOP WAS VECTORIZED.
pardiso_unsym_c.c(155): (col. 2) remark: LOOP WAS VECTORIZED.
Microsoft Incremental Linker Version 8.00.50727.42
Copyright (C) Microsoft Corporation. All rights reserved.
-out:testem64.exe
pardiso_unsym_c.obj
mkl_solver_lp64.lib
mkl_intel_lp64.lib
mkl_core.lib
libiomp5md.lib
Intel C++ Compiler for applications running on Intel 64, Version 10.1 Build 20080
801 Package ID: w_cc_p_10.1.025
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
--Gennady
rlc138
rlcampbell,
pardiso_unsym_c.c
-out:testem64.exe
pardiso_unsym_c.obj
mkl_solver_lp64.lib
mkl_intel_lp64.lib
mkl_core.lib
libiomp5md.lib
--Gennady
Hi Gennady,
It turns out that it was the function name that was the problem - (I was using pardiso_unsym.c not pardiso_unsym_c.c). pardiso_unsym.c trys to link to pardiso_ instead of PARDISO. When I changed the function names, it linked without a problem.
Rob
