PARDISO and DSS
Vahid_Jalili
Hi all,
I wanted to compare the LU factorization time done by DSS and PARDISO on a quad core Intel CPU in MS VS 2008. In PARDISO I have set the iparm(2)=3 to use parallel threads, however I am not seeing any acceleration in compare with DSS or even when iparm(2)=0 or 2.
If PARDIOS is faster than DSS? and if DSS is using parallel threads by default?
ArturGuzik
Valued Contributor I
Vahid,
you won't see any speed up bacause DSS is just a simplier interface to Pardiso. Core is the same.
A.
Gennady_F_Intel
exactly,DSS is just different, simplified interface which provides the same efficiency of calculations.
--Gennady
Vahid_Jalili
You mean both DSS and PARDISO are using all 4 cores of the quad core CPU by default? We don't need to set anything for this purpose, right?
Thank you.
Gennady_F_Intel
It depends of version of MKL you are using. For the latest (10.2 and 10.3) versions that's correct.
--Gennady
