PARDISO and MPI
michaelmoc
Hello!
I have a question about running PARDISO solver under MPI.
Is PARDISO supporting mpi? I mean that if i will compile my program with mpicc to solve big sparse matrix and than i will run it via mpirun command will PARDISO use all MPI nodes ? Or should i just use icc to compile it and than normally run my app?
Gennady_F_Intel
Hello Michael,
the current version of PARDISO (MKL v10.2) doesn't support MPI.
quote:"Or should i just use icc to compile it and than normally run my app?"
yes.
--Gennady
michaelmoc
Thank You for your help.
Best regards, Michael.
