Parallelizing FFT not seeing 100% CPU
Marshall__Michael_B
I am new to using the MKL.
I have the following example:
numElements = 1 << 23;
DftiCreateDescriptor(&complexDescriptor, DFTI_DOUBLE, DFTI_COMPLEX, 1, numElements);
DftiSetValue(complexDescriptor, DFTI_BACKWARD_SCALE, (double) 1 / numElements);
DftiCommitDescriptor(complexDescriptor);
DftiComputeForward(complexDescriptor, compDataArray);
DftiFreeDescriptor(&complexDescriptor);
I have run on both a core2 quad and duo machine running Win XP Pro SP 3. On neither do I see 100 % CPU usage. On the quad, only 2 cores seem to show increased activity.
I inherited this project and I believe I am working with MLK 5.1
Any help would be useful (including how to determine the exact version of the library)
Dmitry_B_Intel
If it works, you must be working withMKL later than 5.1, because that dated version of MKL didn't provide DFTI functions.Function mkl_get_version_string maybe used to determine exact version ifMKL releaseis nottoo old.
Is your OS 32-bit?
Dima
Gennady_F_Intel
Quoting - mimarsh2
mimarch,
1) The current version of MKL is 10.2 Update3 but MKL 5.1 - EOL some years ago,....
2) Starting with Intel MKL 10.0, the OpenMP* software determines the default number of threads. For Intel OpenMP* libraries, the default number of threads is equal to the number of logical processors in your system.
At the same time all MKL's versions before 10.0 ( namely 9.1, 8.1, 7.2 and etc ) support another default threading model: the default number of threads is equal 1.
3) how to determine the exact version of the library?
there are at least 2 ways to define the version:
3.1:please loo at the docmklsupport.txt file. you can find there the packageID data ( like at my installation -- Package ID: w_mkl_p_10.2.3.029 )
that's mean: version 10.2 Update3 build 029
3.2 use runtime routine
mkl_get_version( MKLVersion* pVersion ); See the description into manual or into header files
one notes:
for the obsolete versions there is MKLGetVersion() routine. This is an obsolete name for the mkl_get_version function
4) please look at the Intel MKL Treaded 1D FFT. May be it will usefull for you.
--Gennady
Marshall__Michael_B
I found a more recent version in our company's archives.
I am now using 9.1.026
I am using the exact same code; headers still matched.
The new library does have better performance, but I still don't see both processors pegged.
I am running 32 bit Win XP Pro SP 3.
I found the following snippet in the new documentation.
Intel MKL is threaded in a number of places: direct sparse solver, LAPACK (*GETRF,
*POTRF, *GBTRF, *GEQRF, *ORMQR, *STEQR, *BDSQR routines), all Level 3 BLAS,
Sparse BLAS matrix-vector and matrix-matrix multiply routines for the compressed sparse
row and diagonal formats, and all FFTs (except 1D transformations when
DFTI_NUMBER_OF_TRANSFORMS=1 and sizes are not power of two).
NOTE. For power-of-two data in 1D FFTs, Intel MKL provides parallelism
only for processors based on IA-64 (Itanium processor family) or
Intel 64 architecture. In the latter case, the parallelism is provided for
out-of-place FFTs only.
I am running on a Core 2 Duo which I think is Intel 64 architecture. Do I need to run 64 bit Windows and use the ia64 libraries to parallelize my 1D FFTs?
Thanks again for the help
Gennady_F_Intel
Quoting - mimarsh2
yes,
- the building line will be like: ifort test.f mkl_em64t.lib libguide40.lib
- Please remember about the default behaivior for this version of MKL:
The library uses OpenMP* threading software, which responds to the environmental variable OMP_NUM_THREADS that sets the number of threads to use. If the variableOMP_NUM_THREADS is not set, Intel MKL software will run on one thread. It is recommended that you always set OMP_NUM_THREADS to the number of processors you wish to use in your application.
- and the another Tips for Coding Techniques for FFT functions :
There are additional conditions to gain performance of the FFT functions.
Applications based on IA-32 or Intel 64 architecture. The addresses of the first elements of arrays and the leading dimension values, in bytes (n*element_size), of two-dimensional arrays should be divisible by cache line size, which equals
32 bytes for Pentium III processor
64 bytes for Pentium 4 processor
128 bytes for processor using Intel 64 architecture
--Gennady
