Pardiso MKL_PROGRESS
junlin_xu
I just upgraded MKL library from 10.1.1.022 to 11.3 (positive symmetric matrix)
For 64-bit, I first tried to use static linking with sequential threading using the following lib files:
mkl_intel_lp64.lib, mkl_core.lib, mkl_sequential.lib
The MKL_PROGRESS will get called but with ending percentage of 128% (instead of 100%)
I then use static linking with OpenMP threading using the following lib files:
mkl_intel_lp64.lib, mkl_core.lib, mkl_intel_thread.lib, libiomp5md.lib
The MKL_PROGRESS will not get called at all for In-Core memory.  If I use Out-Of-Core, then MKL_PROGRESS will get called.
Can someone reproduce this in MKL 11.3?
I did not have these problems using MKL 10.1.1.022 version.
Junlin Xu
Ying_H_Intel
Hi Junlin,
Just check with you, you mean MKL 11.3  or the latest MKL version MKL 11.3 update 2. ?
Ying
junlin_xu
I tried with both 11.3 update 1 and update 2.  Both have the bugs stated.
Junlin Xu
Ying_H_Intel
Hi Junlin,
We have not expect such behavior so may i ask one reproducer?
Ying
junlin_xu
Are you saying you cannot reproduce the problem? or are you so lazy as not to bother to reproduce?
Alexander_K_Intel2
Can i ask to add following lines in your example and provide full output?
    char buf[128];
    MKLVersion ver;
    printf("\nMKL release version:\n");
    MKL_Get_Version_String(buf, 128);
    printf("%s\n",buf);
    MKL_Get_Version(&ver);
    printf("    Major version:          %d\n",ver.MajorVersion);
    printf("    Minor version:          %d\n",ver.MinorVersion);
    printf("    Update version:         %d\n",ver.UpdateVersion);
    printf("    Product status:         %s\n",ver.ProductStatus);
    printf("    Build:                  %s\n",ver.Build);
    printf("    Platform:               %s\n",ver.Platform);
    printf("    Processor optimization: %s\n",ver.Processor);
I run example on my side and have not see any issue:
 96 % In thread 0, at stage Pardiso: factor, steps passed 95
In thread 0, at stage Pardiso: factor, steps passed 96
 100 % In thread 0, at stage Pardiso: factor, steps passed 96
In thread 0, at stage Pardiso: factor, steps passed 100
=== PARDISO: solving a complex nonsymetric system ===
Single-level factorization algorithm is turned ON
Summary: ( factorization phase )
Alex
junlin_xu
Alex:
After using your code to diagnosis the MKL version, i found that 11.3.1 does not work while 11.3.2 does work.  I was mistaken in saying that the bug existed in both MKL 11.3.1 and 11.3.2.
Thanks for your help.
Junlin Xu
Ying_H_Intel
Hi
Thanks for report the result. Mkl_progress in pardiso was broken in 11.3.1 and we fix it in mkl 11.3.2.  I believed that’s the reason.
Ying
