Pardiso Silent Failure in Reordering
NachiketG
I have been able to compile, link and run the pardiso_sym.c and pardiso_unsym.c examples that comes with the oneAPI MKL using MS VC++.   However, when I run the examples, both fail silently in the Reordering and Symbolic Factorization phase. Any ideas on how to debug this?
Nachiket
NachiketG
This was because the environment variables were not set in the shell. Running the setvars.bat script solved this.
NachiketG
Ruqiu_C_Intel
It is great to know that you have solved the problem. Thank you for letting the oneMKL community know about your solution.
Ruqiu
