7300 Discussions
Using fgmres to solve large-scale linear equation systems
houjy
 I have used ILP64 successfully.
But I have another question,When I use fgmres to solve large systems of linear equations, some values in the ipar array are equal to -5589219598436180572
Thank you very much
SofeaAzrin_A_Intel
Thank you for your questions. Could you please provide me more details on this? You can provide your configuration setup which might be one of the reason you are getting this error. Or else your example code that you're trying to run.
houjy
This is my code example. I would like to try solving a system of linear equations with a scale of 69335390 or above. Thank you very much.
SofeaAzrin_A_Intel
May I know if you have any updates on this?
