7303 Discussions
Pardiso does not scale well in reordering step
li__wei
Hi eveyrone,
I have been solving a large symmetric indefinite sparse matrix using Pardiso symmetric solver, with property as below:
< Linear system Ax = b > (Upper half)
             number of equations:           107694
             number of non-zeros in A:      714952
             number of non-zeros in A (%): 0.006164
             number of right-hand sides:    1
However, it does not scale well in reorder step. Could anyone help?
  • thread = 1
reorder: 0.410754 s
factorize: 0.159544 s
solution: 0.047355 s
  • thread = 2
reorder: 0.404389 s
factorize: 0.073979 s
solution: 0.049030 s
  • thread = 4
reorder: 0.417474 s
factorize: 0.054813 s
solution: 0.038233 s
My laptop has 8 CPU, with details as below:
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                8
On-line CPU(s) list:   0-7
Thread(s) per core:    2
Core(s) per socket:    4
Socket(s):             1
Vendor ID:             GenuineIntel
CPU family:            6
Model:                 60
Stepping:              3
CPU MHz:               2594.000
BogoMIPS:              5188.00
Virtualization:        VT-x
Detailed information is in attachment.
Thanks for help!
Alexander_K_Intel2
Hi, Is your matrix have blocked structure? Can you try set iparm[36] to -90 and rerun your test? Thanks, Alex
li__wei
Hi Alexander,
Thanks for reply.
The matrix is a KKT system from FEM stiffness matrix and lagrange mutipliers. It has structure as below:
in which A is the n x n stiffness matrix from a FEM structure, Λ is a m x n lagrange multipliers matrix, usually m << n, ε is a very small perturbation.
 When I set the iparm[36] to -90,
  • thread = 1
reorder time: 0.205429 s
  • thread = 2
reorder time: 0.141978 s
  • thread = 4
reorder time: 0.127079 s
It does scale somehow. Is this desired scalability for Pardiso?
The Pardiso manual does not mention what iparm[36] is for. What does setting it to -90 mean?
The output files are in attachment.
Btw, the residual is computed from ||Ax - b||2 / ||b||2,
  • iparm[36] = 0
residual = 4.208551e-15
  • iparm[36] = -90
residual = 5.733099e-12
Thanks!
Ying_H_Intel
Hi Li Wei,
​It looks a problem. Could you provide us your test matrix and command line, a test code will be better.
​and FYI,  as i mentioned in  topic: https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/777236
  MKL 2018 update 2  have some update about Pardiso routine,  you may try it .
https://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-2018-bug-fixes-list
MKLD-2776 Improved the performance of Intel MKL Pardiso routine in the case of multiple RHS and linking with Intel® Threaded Building Blocks (Intel® TBB) threading layer.
Ying
li__wei
Ying H. (Intel) wrote:
Hi Li Wei,
​and FYI,  as i mentioned in  topic: https://software.intel.com/en-us/forums/intel-math-kernel-library/topic/...
https://software.intel.com/en-us/articles/intel-math-kernel-library-inte...
MKLD-2776
Ying
Thanks for your reply!
Here is the matrix in CSR format. bs is right-hand side vector, row-ptr and col-ind are row and column vectors, val is matrix value.
testPardisoSym.cpp is the code I used to test Pardiso, and makefile.txt(remove .txt) is the makefile I used to compile.
I will try the update 2 to see if scalability improves.
Best,
Ying_H_Intel
Hi Wei,
Thank you for the test code. I can reproduce the problem with latest version.  Will look into details.
Ying
Gennady_F_Intel
the problem has been fixed into version 2019 u3.
