7303 Discussions
Pardiso_handle_store issue with Schur complement computation
Niels_G
I am using Pardiso  (a version from 2020) to solve a symmetric positive definite sparse linear system and I need to compute and export the Schur complement in CSR format from the factorization. Pardiso phases are called from a fortran (77) code. The following parameters iparm(24) = 1, iparm(36)=-2 are set. I also need in my code to store the complete structure of the factorization in a file. I have already used pardiso_handle_store in the passed for another case with a classical factorization method (no schur complement computed) and it worked fine.
But in this case, pardiso_handle_store is crashing with parameters 24 and 36 set to 1 and -2(even with 1, 2 and -1). If iparm(24) is set to 0 and iparm(36) to -2 handle_store works but I can't get the schur complement. So my question is simple : is it possible to use iparm(36) = -2, iparm(24)=1, export the Schur complement in a CSR format and use pardiso_handle_store?
Thank you,
Niels
VarshaS_Intel
Could you please let us know the OS details and hardware you are using?
Also, could you please provide us with the complete sample reproducer code(any other dependent/input files) you are using to investigate more on your issue?
Could you please let us know what kind of error you are facing? Also, you can give a try with the latest oneMKL 2023.1 which is available for download. You can get that by downloading oneAPI Base Toolkit (https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html) and let us know if it still crashes with the latest version.
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide us with details and an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
Since you had raised another query https://community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/Wrong-solution-at-phase-333-with-schur-complement-option/m-p/1491897, we will no longer monitor this thread here. We will continue addressing this issue in the other thread.
Have a Good Day!
Thanks & Regards,
Varsha
