Pardiso memory leak
Dogan__Hakan
I have the following subroutine works perfectly. However, I am using it in a nonlinear solution. I call it many times in a program. After each call, the memory usage increases, though I am using 'Release memory' option at the end of the subroutine. Does anyone have an idea what may be the reason for memory increase here? Is there any way of chasing the variables at the begining and the end of subroutine; so that I can see which of them stay unreleased?
Many thanks.
SUBROUTINE SPARSE_SOL
      USE XX  ! this is module of already allocated variables
      integer omp_get_max_threads
      external omp_get_max_threads
      !This is OK in both cases
      INTEGER*8 pt(64)
      !All other variables
      INTEGER maxfct, mnum, mtype, phase, n, nrhs, error, msglvl
      INTEGER i, idum
      INTEGER iparm(64)
      REAL*8 waltime1, waltime2, ddum
      complex*16 cdum
      ! Fill all arrays containing matrix data.
      DATA nrhs /1/, maxfct /1/, mnum /1/
      n = nodes
      !Set up PARDISO control parameter
      do i = 1, 64
            iparm(i) = 0
      end do
      iparm(1) = 1 ! no solver default
      iparm(2) = 2 ! fill-in reordering from METIS
      iparm(3) = mkl_get_max_threads()
      ! numbers of processors, value of MKL_NUM_THREADS
      iparm(4) = 0 ! no iterative-direct algorithm
      iparm(5) = 0 ! no user fill-in reducing permutation
      iparm(6) = 0 ! =0 solution on the first n components of x
      iparm(7) = 0 ! not in use
      iparm(8) = 9 ! numbers of iterative refinement steps
      iparm(9) = 0 ! not in use
      iparm(10) = 13 ! perturb the pivot elements with 1E-13
      iparm(11) = 1 ! use nonsymmetric permutation and scaling MPS
      iparm(12) = 0 ! not in use
      iparm(13) = 0 ! not in use
      iparm(14) = 0 ! Output: number of perturbed pivots
      iparm(15) = 0 ! not in use
      iparm(16) = 0 ! not in use
      iparm(17) = 0 ! not in use
      iparm(18) = -1 ! Output: number of nonzeros in the factor LU
      iparm(19) = -1 ! Output: Mflops for LU factorization
      iparm(20) = 0 ! Output: Numbers of CG Iterations
      iparm(60) = 1 ! OOC core selection
      error = 0 ! initialize error flag
      msglvl = 1 ! print statistical information
      mtype = 13 ! COMPLEX unsymmetric
      !Initialize the internal solver memory pointer. This is only
      !necessary for the FIRST call of the PARDISO solver.
            do i = 1, 64
                  pt(i) = 0
            end do
      !Reordering and Symbolic Factorization, This step also allocates
      !all memory that is necessary for the factorization
      phase = 11 ! only reordering and symbolic factorization
      CALL pardiso (pt,maxfct,mnum,mtype,phase,nodes, valuesCoo,  &
        rowIndex, colsCoo, idum, nrhs, iparm, msglvl, cdum, cdum, error)
      WRITE(*,*) 'Reordering completed ... '
      IF (error .NE. 0) THEN
             WRITE(*,*) 'The following ERROR was detected: ', error
             pause
      END IF
      WRITE(*,*) 'Number of nonzeros in factors = ',iparm(18)
      WRITE(*,*) 'Number of factorization MFLOPS = ',iparm(19)
      !Factorization.
      phase = 22 ! only factorization
      CALL pardiso(pt,maxfct,mnum,mtype, phase,nodes, valuesCoo,  &
        rowIndex, colsCoo,idum, nrhs, iparm, msglvl, cdum, cdum, error)
      WRITE(*,*) 'Factorization completed ... '
            pause
      ENDIF
      !Back substitution and iterative refinement
      iparm(8) = 2 ! max numbers of iterative refinement steps
      phase = 33 ! only factorization
!      do i = 1, n
!            b(i) = 1.d0
!      end do
      CALL pardiso(pt,maxfct,mnum,mtype,phase,nodes, valuesCoo,  &
        rowIndex,colsCoo,idum, nrhs, iparm, msglvl, bglb, sln, error)
      WRITE(*,*) 'Solve completed ... '
      !Termination and release of memory
      phase = -1 ! release internal memory
      CALL pardiso (pt, maxfct, mnum, mtype, phase, nodes, ddum, idum, idum,  &
      idum, nrhs, iparm, msglvl, ddum, ddum, error)
      RETURN
      END
Chao_Y_Intel
In order to improve the performance, Intel MKL internally maintain one memory buffer, such buffer will be freed when the application exit.  But if you want to free these buffers by yourself, you need to call some MKL APIs explicitly. Check the MKL user guide for more info:
http://software.intel.com/sites/products/documentation/doclib/mkl_sa/11/mkl_userguide_win/GUID-5E240159-8AE3-4507-91FE-43BA6DBAF6F2.htm
Chao
