Pardiso multi processor
eh4
Hi all,
I have been reading many posts here about trying to let PARDISO run in more than processor. However, I still cant get a proper idea on how this can be done.
What I have done is:
call omp_set_num_threads(4).
iparm(1) = 1 ! no solver default
iparm(2) = 3 ! fill-in reordering from METIS
iparm(3) = 4 ! numbers of processors, value of MKL_NUM_THREADS
iparm(4) = 0 ! no iterative-direct algorithm
iparm(5) = 0 ! no user fill-in reducing permutation
iparm(6) = 0 ! =0 solution on the first n components of x
iparm(7) = 0 ! not in use
iparm(8) = 20 ! numbers of iterative refinement steps
iparm(9) = 0 ! not in use
iparm(10) = 13 ! perturb the pivot elements with 1E-13
iparm(11) = 1 ! use nonsymmetric permutation and scaling MPS
iparm(12) = 0 ! not in use
iparm(13) = 1 ! not in use
iparm(14) = 0 ! Output: number of perturbed pivots
iparm(15) = 0 ! not in use
iparm(16) = 0 ! not in use
iparm(17) = 0 ! not in use
iparm(18) = -1 ! Output: number of nonzeros in the factor LU
iparm(19) = -1 ! Output: Mflops for LU factorization
iparm(20) = 0 ! Output: Numbers of CG Iterations
iparm(27) = 1 !Matrix checker on
iparm(60) = 1
During the run, it always say that the number of procesors use is 1.
(Direct factorization using #processors) 1
Does this mean that only one processor is running?
The machine that I am using is Intel Xeon W55803.2GHz. There are 4 physical processors. The funny thing is when i check the task manager, all 4 processors are running to 100% during factorization.
Thank you.
EH
Alexander_K_Intel2
Could you provide size of your matrix?
With best regards,
Alexander Kalinkin
eh4
Hi Alex,
There are 113762 equations. The matrix is sparse and the number of nonzeros are 11741784
The PARDISO is running in the in-core mode
Do I need to specify anything for mkl_num_threads and omp_num_threads?
Thank you.
Best wishes,
EH
Alexander_K_Intel2
Size of matrix is pretty big so PARDISO could run in multithread mode... Could you provide us linkline of your project?
With best regards,
Alexander Kalinkin
eh4
Hi Alex,
Sorry because I am not very familiar with the programming jargons. I have here the entire subroutine where pardiso is called. Would this help? If not, could you tell me what linkline of a project is?
Thank you and sorry for the inconvenience.
SUBROUTINE PARDISO_SOLVER(Nc,n,A,ia,ja,Bin,Z)
! SUBROUTINE PARDISO_SOLVER(Nc,n,Ain,iin,jin,Bin,Z)
! THIS SUBROUTINE CALLS THE SOLVER PARADISO TO SOLVE THE SYSTEM...
! OF LINEAR ALGEBRAIC EQUATIONS
IMPLICIT NONE
! Internal solver memory pointer for 64-bit architectures
! INTEGER*8 pt(64)
! Internal solver memory pointer for 32-bit architectures
! INTEGER*4 pt(64)
! This is OK in both cases
! DOUBLE PRECISION, ALLOCATABLE :: A(:)
! INTEGER, ALLOCATABLE :: ia(:), ja(:)
INTEGER*4 pt(64)
INTEGER maxfct, mnum, mtype, phase, n, nrhs, error, msglvl, Nc, i, idum
INTEGER iparm(64)
INTEGER ja(Nc), ia(n+1)
DOUBLE PRECISION A(Nc), Bin(n), Z(n)
DOUBLE PRECISION waltime1, waltime2, ddum
INTEGER mkl_get_max_threads
INTEGER MKL_NUM_THREADS,OMP_NUM_THREADS
EXTERNAL mkl_get_max_threads
EXTERNAL omp_num_threads
MKL_NUM_THREADS=2
call OMP_SET_NUM_THREADS(4)
! Set up PARDISO control parameter
DO i=1,64
iparm(i) = 0
END DO
iparm(60) = 1
error = 0 ! initialize error flag
msglvl = 1 ! print statistical information
mtype = 11 ! real unsymmetric
maxfct=1
mnum=1
nrhs=1
! Initialize the internal solver memory pointer. This is only...
! necessary for the FIRST call of the PARDISO solver.
DO i=1,64
pt(i) = 0
END DO
! Reordering and Symbolic Factorization, This step also allocates...
! all memory that is necessary for the factorization
phase = 11 ! only reordering and symbolic factorization
CALL pardiso(pt,maxfct,mnum,mtype,phase,n,A,ia,ja,idum,nrhs,iparm,msglvl,ddum,ddum,error)
WRITE(*,*) 'Reordering completed ... '
IF (error .NE. 0) THEN
WRITE(*,*) 'The following ERROR was detected: ', error
PAUSE
STOP
END IF
WRITE(*,*) 'Number of nonzeros in factors = ',iparm(18)
WRITE(*,*) 'Number of factorization MFLOPS = ',iparm(19)
! Factorization.
phase = 22 ! only factorization
WRITE(*,*) 'Factorization completed ... '
PAUSE
STOP
ENDIF
! Back substitution and iterative refinement
iparm(8) = 20 ! max numbers of iterative refinement steps
phase = 33 ! only factorization
CALL pardiso(pt,maxfct,mnum,mtype,phase,n,A,ia,ja,idum,nrhs,iparm,msglvl,Bin,Z,error)
WRITE(*,*) 'Solve completed ... '
! Termination and release of memory
phase = -1 ! release internal memory
CALL pardiso(pt,maxfct,mnum,mtype,phase,n,ddum,idum,idum,idum,nrhs,iparm,msglvl,ddum,ddum,error)
! DEALLOCATE(A,ia,ja)
RETURN
END
Thank you.
Best wishes,
EH
Alexander_K_Intel2
Ok. If you run your program from visual studio you put several mkl library names in field names "additional libraries" or something like it... If you run you example from command line you call some command to compile and run it. Could you provide names of mkl library in first case or command in second case?
Also, could you print result ofmkl_get_max_threads() before first call of PARDISO?
With best regards,
Alexander Kalinkin
eh4
I did not put in any mkl library names. Instead, under Properties -> Fortran -> Libraries:Include Math Kernel Library option, I chose the Parallel (/Qmkl:parallel) options. Is this not the correct way of doing it?
Regarding the mkl_get_max_threads(), the printed value was 4. However the Parallel Direct Factorization with #provessors still say 1.
EH
Alexander_K_Intel2
One additional question, I hope the last one: which version of stufio do you use?
With best regards,
Alexander Kalinkin
eh4
I am using Microsoft Visual Studio 2008, Version 9.0.21022.8 RTM. The installed product is Intel Visual Fortran Compiler Integration.
Konstantin_A_Intel
Hi, could you please go to
Project -> Your Project Properties... -> Configuration Properties -> Linker -> Command line
and send us the content of this text field?
Konstantin
Gennady_F_Intel
actually, if customer set the option(/Qmkl:parallel ), then it would be enough to link all threading runtime.
but, for eliminations all concerns, You can explicitly toset all requiredlibraries for your application and check how it would works on your side.
as an additional info, it might be useful for you to see this KB article shows how configure Intel MKL in Microsoft* Visual Studio.
eh4
The content in the Command line reads:
/OUT:"x64\Debug\Test1.exe" /INCREMENTAL:NO /NOLOGO /LIBPATH:"C:\Program Files\Intel\Compiler\11.1\048\mkl\ia64\lib" /MANIFEST /MANIFESTFILE:"D:\USERS\EHOOI\Fortran\3D\Natural_Convection\Test3-steady\x64\Debug\Test1.exe.intermediate.manifest" /DEBUG /PDB:"D:\USERS\EHOOI\Fortran\3D\Natural_Convection\Test3-steady\x64\Debug\Test1.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"D:\USERS\EHOOI\Fortran\3D\Natural_Convection\Test3-steady\x64\Debug\Test1.lib"
Thank you.
EH
eh4
Hi Konst
Thank you. I will check it out. By the way, if all four CPU in the Task Manager show 100% computation during the running of PARDISO (only fortran is running), then is this an indicator that it is using 4 processors in parallel although in the Command Window it says 1 processor in the Direct Factorization?
Thank you.
EH
Konstantin_A_Intel
Hmm, it's strange that you useIntel Xeon W5580, but it seems like you are linking with IA-64 architecture (Itanium-2):
Also you can easily understand is your code parallelized or not running your program in 2 modes: with mkl_set_num_threads(1); and mkl_set_num_threads(4); set prior to calling PARDISO andcompare the timings reported.
Konstantin
eh4
When I let mkl_set_num_threads(4), during PARDISO all 4 CPUs in Task manager were running at 100%. However, when I change it to mkl_set_num_threads(1), only 1CPU is running. I guess it is running in parallel, although I dont know why the CommandWindow says only 1 processor is running for the Direct Factorization.
Is it wrong to link with the IA-64 architecture?
BW,
EH
