MKL PARDISO statistics
xian-zhong_guous_cd-
From the following PARDISO statistics, it seems solving for rhs (solve to solve) is domainant. This does not seem to consistent with my expection: I expect factorization (factorize to factorize) is domainant.
PARDISO stattistics starts here:
ooc_max_core_size got by Env = 20000
The file ./pardiso_ooc.cfg was not opened
=== PARDISO is running in Out-Of-Core mode, because iparam(60)=1 and there is not enough RAM for In-Core ===
================ PARDISO: solving a symm. posit. def. system ================
Summary PARDISO: ( reorder to reorder )
Times:
Time fulladj: 0.684705 s
Time reorder: 89.446126 s
Time symbfct: 9.093952 s
Time parlist: 23.178850 s
Time malloc : 1.119903 s
Time total : 155.063945 s total - sum: 31.540409 s
Statistics:
< Parallel Direct Factorization with #processors: > 8
< Numerical Factorization with BLAS3 and O(n) synchronization >
< Linear system Ax = b>
#equations: 5389726
#non-zeros in A: 42250735
non-zeros in A (%): 0.000145
#right-hand sides: 1
< Factors L and U >
#columns for each panel: 96
#independent subgraphs: 0
< Preprocessing with state of the art partitioning metis>
#supernodes: 2241484
size of largest supernode: 9951
number of nonzeros in L 3046299967
number of nonzeros in U 1
number of nonzeros in L+U 3046299968
Percentage of computed non-zeros for LL^T factorization
0 % 1 % 2 % 3 % 4 % 5 % 6 % 7 % 8 % 9 % 10 % 11 % 12 % 13 % 14 % 15 % 16 % 17 % 18 % 19 % 20 % 21 % 22 % 23 % 24 % 25 % 26 % 27 % 28 % 29 % 30 % 31 % 32 % 33 % 34 % 35 % 36 % 37 % 38 % 39 % 40 % 41 % 42 % 43 % 44 % 45 % 46 % 47 % 48 % 49 % 50 % 51 % 52 % 53 % 54 % 55 % 56 % 57 % 58 % 59 % 60 % 61 % 62 % 63 % 64 % 65 % 66 % 67 % 68 % 69 % 70 % 71 % 72 % 73 % 74 % 75 % 76 % 77 % 78 % 79 % 80 % 81 % 82 % 83 % 84 % 85 % 86 % 87 % 88 % 89 % 90 % 91 % 92 % 93 % 94 % 95 % 96 % 97 % 98 % 100 %
Summary PARDISO: ( factorize to factorize )
Times:
Time A to LU: 0.000000 s
Factorization: Time for writing to files : 0.000000
Factorization: Time for reading from files : 0.000000
Time numfct : 663.914768 s
Time malloc : 0.000054 s
Time total : 663.954133 s total - sum: 0.039310 s
Statistics:
#equations: 5389726
< Factors L and U >
gflop for the numerical factorization: 11175.376693
gflop/s for the numerical factorization: 16.832547
Summary PARDISO: ( solve to solve )
Times:
Solution: Time for reading from files : 0.000000
Time solve : 716.844178 s
Time total : 1867.447714 s total - sum: 1150.603536 s
----------- Out of core time (in percent (%)) --------------
Factorization step (100 (%)):
write to files : 0
read from files: 0
factorization - write&read : 100
Solution step (100 (%)):
read from files: 0
solve - write&read: 100
Total time (100 (%)):
read from files: 0
total - write&read: 100
----------- Out of core Mb --------------
Factorization step:
write to files : 0.000 Mb
read from files: 0.000 Mb
Solution step:
Total size of data transferred :
write&read : 0.000 Mb
Statistics:
#equations: 5389726
< Factors L and U >
Sergey_Solovev__Inte
In In-Core mode solving step is faster than factorization one.
In OOC mode following situation can be happened: factorisation step doesnt read L-factors, just saves. Solving step reads all L-factor twice: at first during forward step, secondly during backward one. Let me note, if iterative refinement step (iparm(8)) is switch on, so solving step can be significantly slower because PARDISO should read L-factors several times.
Regards, Sergey
eh4
May I know how you got Pardiso to run with 8 processors? Of couse you need to have 8 physical processors. My machine has 4 processors and I have the line
CALL OMP_SET_NUM_THREADS(4)
in my subroutine. However, when I run it, the report says that the number of processors used in the factorization is 1. When I printedomp_get_max_threads() it shows value of 4.
Am I missing something?
Thank you.
Sincerely,
EH
What the mode of PARDISO do youuse: InCore or OOC ? And what the version of MKL?
Our quick advice is to use call mkl_set_num_threads(4) for setting MKL_NUM_THREADS environment variable.
Thank you!
Sergey
